Get UTC date time and convert to bytes using VisualLisp
I'm new to AutoLisp. I am wondering if there is a way to get DateTime in UTC.
I know we can use CDate and Date but it only return PC date.
And also how to convert Date Time to bytes?
Thank you so much
hencoop
I'm not sure of exactly what you are looking for but DOSLIB from Robert McNeel & Associates has some date tools (and lots of other good tools) that could help you.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
I need to get current UTC datetime with autolisp.
I tried common lisp comand use (get-universal-time) . It will return
                        ; error: no function definition: GET-UNIVERSAL-TIME
Now my code is
(defun c:testing
  (setq time (rtos (getvar "CDATE")))
  (princ)
  (princ time)
  (princ)
It returns
20170329.0941  (current PC datetime)
I need to return
20170329.0141  (current UTC datetime)
dbroad
If you're trying to get a time 8 hours earlier in a string similar to CDATE, then this should work:
(menucmd "M=$(edtime,$(-,$(getvar,date),0.3333333333),YYYYMODD\".\"HHMMSSMSEC)")
Architect, Registered NC, VA, SC, & GA.
