Visual LISP, AutoLISP and General Customization
Get the server name where drve X is mapped.
2 REPLIES 2
mdhutchinson
347 Views, 2 Replies
How can I access the system info to get what server name a network dirve is mapped with visual lisp?
2 REPLIES 2
Gary_J_Orr
in reply to: mdhutchinson
For Windows file system information I usually use the Windows "Scripting.FileSystemObject"
Help can be found at Microsoft.com developer help.
Some basics to get you started (copied out of an old file syncronizing utility):
  (princ "\nStarting scripting Interface")
  (setq scrptobj (vla-getinterfaceobject (vlax-get-acad-object) "scripting.filesystemobject"))
;get a folder
    (setq sourcefoldobj (vlax-invoke-method scrptobj "getfolder" sourcefolder))
;get a drive
    (setq sourcedrv (vlax-get-property sourcefoldobj "Drive"))
    ;Check Drive types
    ;0=unknown
    ;1=removable(floppy/zip)
    ;2=fixed(hard drive)
    ;3=remote(network)
    ;4=cdrom
    ;5=ramdisk???
    (if (= 2 (vlax-get sourcedrv "DriveType"))
      (progn
	(alert "Check Drive Mappings. You're copying from a Local Hard Drive")
	(exit)
A few vlax-dump-object calls on some of the above may get you a long way.
Happy Lisping
-Gary
Gary J. Orr
(Your Friendly Neighborhood) CADD/BIM/VDC Applications Manager
http://www.linkedin.com/in/garyorr
aka (current and past user names):
Gary_J_Orr (GOMO Stuff 2008-Present); OrrG (Forum Studio 2005-2008); Gary J. Orr (LHB Inc 2002-2005); Orr, Gary J. (Gossen Livingston 1997-2002)
Gary_J_Orr
in reply to: Gary_J_Orr
I posted that one kinda quick but using that "getInterfaceobject" call as an example of translating here are some additional objects that you may need (taken from a VBScript routine):
Set netObject = WScript.CreateObject("WScript.Network")
Set shlObject = WScript.CreateObject("WScript.Shell")
set fsObject = wscript.createobject("Scripting.FileSystemObject")
fsObject.DriveExists("O:")
set fsoDrive = fsObject.GetDrive("O:")
netObject.MapNetworkDrive "O:", "\\DESIGN\CAD_MGMT"
I hope that I haven't made your day any more complicated than it already was
-G
Gary J. Orr
”Boost
