get points around circle
rpajounia
rpajounia
is there a way i can get all the points around the circle for example  p1 and p2 are 1 distance apart and then p2 and p3 will be 1 distance apart
-didier-
Bonjour @rpajounia
Here is a very simple solution with an LSP file.
You have to click the circle, the point on the circle to define the start of the distance and the desired distance.
A small circle will be drawn at the given distance from the starting point counterclockwise.
This is a very simple first version to understand your request, I can work to improve it...
The point for the start of distance must be on the circle, I have not done a snag test
Amicalement
(defun c:disc ( / dis ent pt pt2)
    (setq ent (car (entsel"\nCircle ?\n")))
    (setq pt (getpoint "\nStart point for distance ?\n"))
    (setq dis (getreal "\nDistance for desired point\n"))
    (setq pt2 (vlax-curve-getpointatdist ent
              (+ dis (vlax-curve-getdistatpoint ent pt))))
    (command "_circle" pt2 0.1)
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Kent1Cooper
By "get all the points" do you mean you want to save the coordinate lists of all the locations, or do you want to put Point objects along the Circle at regular spacings?  If the latter, MEASURE will do that for you.
Kent Cooper, AIA
calderg1000
Regards @rpajounia
Try this code, it inserts circles from a starting point in a constant measure for all the sections. With the option to choose the clockwise or counterclockwise insertion direction.
(defun c:test (/ s sn l r ds n i dsp opc f p)
  (setq s  (ssget "_+.:E:S" '((0 . "circle")))
        sn (vlax-ename->vla-object (ssname s 0))
        l  (vlax-get sn 'circumference)
        r  (vlax-get sn 'radius)
  (setq ds (getreal "\nEnter distance to measure:")
        n  (fix (/ l ds))
        i  1
  (setq dsp (vlax-curve-getdistatpoint sn (getpoint "\nPick Point Start:")))
  (initget "W C")
  (setq opc (getkword "\nClockwise/Counter-clock wise: [W/C] <W>:"))
  (if (= opc "W")
    (setq f '-)
    (setq f '+)
  (repeat n
    (setq p (vlax-curve-getpointatdist sn (apply f (list dsp (* i ds)))))
    (entmake
      (list '(0 . "circle")
            (cons 10 p)
            (cons 40 (/ r 100.))
    (setq i (1+ i))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
rpajounia
perfect thank you soo much
