@DC-MWA wrote:
Points in between 1st and 2nd pick
(Defun c:STW (/ fp sp pl verts thistwopoints n) ; Show These points
;; pBe May 2020 ;;;
(defun xy (p)(list (Car p)(cadr p)))
(if
(and
(setq fp (getpoint "\nPick first reference point"))
(setq sp (getpoint fp "\nPick next point"))
(setq pl (car (nentselp fp)))
(progn
(setq verts (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget pl))))
(setq thistwopoints (vl-sort (mapcar '(lambda (w)
(vl-position (xy w) verts))(list fp sp)) '<))
((lambda (n)
(repeat (1- (/ (abs (apply '- thistwopoints)) 2))
;; repeated function here
(entmake (list (cons 0 "POINT") (cons 10 (nth (setq n (+ 2 n)) verts))))
(car thistwopoints)
(princ)
If you want to include all points including 1st and second pick
((lambda (n)
(repeat (1+ (/ (abs (apply '- thistwopoints)) 2))
(entmake (list (cons 0 "POINT") (cons 10 (nth n verts))))
(setq n (+ 2 n))
(car thistwopoints)
If you only want to include ONLY the first pick [ the direction of the polyline plays a role here, you can add check for polylline direction ]
((lambda (n)
(repeat (/ (abs (apply '- thistwopoints)) 2)
(car thistwopoints)
HTH
