Get point of X,Y coord. from Xref object
Automohan
Message 1 of 15
Automohan
Dear Colleagues,
Will a Lisp function will choose a point object X,Y coordinate from Xref with a specific layer?
Kind Regards
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
Replies (14)
Message 2 of 15
-didier-
Bonjour @Automohan
  1. I don't quite understand the question
    Do you want to use getpoint?... It will work
  2. Do you want to know the coordinates of a specifically defined point (intersection, extremity, of an entity)
    located in the xref?
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 3 of 15
Automohan
White color rectangle (Drawing border) + red color point + green color point are Xref ojects !
For the Pagesetup lisp red color point X,Y & green color point X,Y is required !
Note:
Red color point is not layer 1, it should be layer 2
Green color point is not layer 1, it should be layer 3
Getpoint of X,Y coord. of a point on a specific layer 2
Getpoint of X,Y coord. of a point on a specific layer 3
"Save Energy"
Message 4 of 15
Sea-Haven
If its a rectang title block etc the (getvar 'extmax & extmin may give you what you want.
Message 5 of 15
-didier-
Bonjour @Automohan
These explanations do not allow me to understand
  • These points are unique?
  • One point per layer?
  • They are blocks?
Please show an example of dwg with xrefs
AMicalement
DA
Message 6 of 15
Moshe-A
@Automohan ,
As @-didier-  said, your explanations are not clear at all. to get the coordinates of an xref, you can do something similar as the attached code (BB command). (vla-BoundingBox) function can return the surrounding box of any object. it returns the minpoint which is the lower left corner and maxpoint which is the upper right corner. from there you can easily figure your points 😀
enjoy
Moshe
; return bounding box of block references
(defun c:BB (/ ss AcDbBlkRef MinPoint MaxPoint p0 p1)
 (if (setq ss (ssget ":s:e+." '((0 . "insert"))))
  (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
   (setq AcDbBlkRef (vlax-ename->vla-object ename))
   (vla-GetBoundingBox AcDbBlkRef 'MinPoint 'MaxPoint)
   (setq p0 (vlax-safearray->list MinPoint))
   (setq p1 (vlax-safearray->list MaxPoint))
   (foreach a (list p0 " " p1)
    (princ a)
   (vlax-release-object AcDbBlkRef)
  ); foreach
 ); if
 (princ)
Message 7 of 15
Automohan
Our drawing frames all are Xrefs only (not blocks)
I have attached our drawing frame cad format.
"Save Energy"
Message 8 of 15
john.uhden
Why not just do a pagesetup first, then there's no need to go picking around thereafter.
Then again, if you're not using paperspace, you should be.
John F. Uhden
Message 9 of 15
Moshe-A
@Automohan ,
@Automohan wrote:
Dear Colleagues,
Kind Regards
Getting an XY coordinates of a point in cross layers. a point on "layer1" is the same point on "layer2"...."layerN"
so we not exactly understand what you mean by "coordinate from Xref with a specific layer?"
"Our drawing frames all are Xrefs only (not blocks)"
for your knowledge, an xref is private case of a block.
attached an update to BB command.
Moshe
(defun c:BB (/ ss AcDbBlkRef MinPoint MaxPoint p0 p1 p2 p3)
   (setq p2 (vlax-safearray->list MaxPoint))
   (setq p1 (list (car p2) (cadr p0)))
   (setq p3 (list (car p0) (cadr p2)))
   (foreach a (list p0 " " p1 " " p2 " " p3)
    (princ a)
  ); foreach
 ); if
 (princ)
Message 10 of 15
Sea-Haven
As suggested if in a layout with 1 xref title block this may be useful.
(setq ss (ssget "X" (list (cons 0 "INSERT")(cons 2 "yourxrefame")(cons 410 (getvar 'ctab)))))
Message 11 of 15
john.uhden
But why would he need one PS coordinate to plot?
Pagesetup... ready to plot (again and again).
I wonder if he's heard about Sheet Set Manager.
John F. Uhden
Message 12 of 15
Automohan
Getting Error !
"Save Energy"
Message 13 of 15
Automohan
I never use Sheet Set Manager I have to go through it !
I know i can do a Pagesetup & insert to many drawings & apply, but some drawings got moved mistakenly (error)
My Idea is to create a Page setup lisp then load with a Script to run.
I look forward to hear your opinion or any ideas.
"Save Energy"
Message 14 of 15
Moshe-A
@Automohan ,
Never heard c:bb is a protected symbol but you are invited to change it to what ever you choose
Moshe
Message 15 of 15
john.uhden
Is your idea based on previous programming experience or is it wishful thinking?
There are many fine people here who donate their time with the intent of helping others learn to improve their AutoLisp programming skills.  Yet there is a plethora of visitors who just want a custom solution built for them for free to save them time and effort.  Ya know, if such needy visitors were willing to pay for the expertise they receive it would be fair.  But a very very few are willing, and it bugs the $#*^! out of me.
My apologies if I have misinterpreted your intent.
John F. Uhden
