Get Mtext width formatting value
msarqui
msarqui
Hi guys,
How can I put in a variable the value of a Mtext width formatting?
For exemple, in a Mtext with a width of 1.2, I have this TextString in VLA: "{\\W1.20000000;Example}". in this case it would be the value between "W" and ";".
But, if the Mtext has no width formatting, I have only this TextString "Example"
So, regardless all kinds of formatting, how can I extract this value?
Thanks for your help
Marcelo
ВeekeeCZ
Try this...
  (if (and (setq txt (cdr (assoc 1 (entget (car (entsel))))))
           (vl-string-search "\W" txt))
    (atof (substr txt (+ 2 (vl-string-search "\W" txt)))))
Remember that there could be more than one occurrence.
msarqui
Thanks Bee!
ВeekeeCZ
You're welcome. Seeing that, you should add 1 as 'else' value. But you probably figured it out yourself 🙂
