Get longest STRLEN of multiple variables
Message 1 of 8
I have multiple STRLEN variables and I'm looking to find the longest of them all.
It doesn't matter which variable is longest, I just need to know the length of the longest string from these variables
(SETQ HDRLG(STRLEN HEADER))
(SETQ THRLG(STRLEN THLBL))
(SETQ JTLG1(STRLEN JTLBL1))
(SETQ JTLG2(STRLEN JTLBL2))
(SETQ JTLG3(STRLEN JTLBL3))
(SETQ JTLG4(STRLEN JTLBL4))
(SETQ JTLG5(STRLEN JTLBL5))
(SETQ JTLG6(STRLEN JTLBL6))
(SETQ JTLG7(STRLEN JTLBL7))
(SETQ JTLG8(STRLEN JTLBL8))
Thanks in advance,
Larry
Replies (7)
Message 2 of 8
Alexander.Rivilis
(max
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 8
Kent1Cooper
@Anonymous wrote:
... I just need to know the length of the longest string from these variables
Or, if you don't actually need those string lengths stored into separate variables for some purpose(s) other than finding the length of the longest one, you can skip the string-length variables entirely, and get the answer straight from the string variables themselves:
(apply 'max
  (mapcar 'strlen
    (list HEADER THLBL JTLBL1 JTLBL2 JTLBL3 JTLBL4 JTLBL5 JTLBL6 JTLBL7 JTLBL8)
Kent Cooper, AIA
Message 4 of 8
As usual you always come through with a solution, but my lack of LISP knowledge is getting the best of me again
I'm not sure how to apply your solution to a variable equal to the maximum length of those in the list
I tried
(setq elwt
  (apply 'max
    (mapcar 'strlen
but that wasn't correct
Message 5 of 8
Kent1Cooper
@Anonymous wrote:
I tried
(setq elwt
  (apply 'max
    (mapcar 'strlen
What does it return when you run that?  It does require that the content of all those variables are, in fact, text strings, and that they all exist [because (strlen) will have a problem trying to find the length of a non-existent string].  If it's only that they might not always all be present, it's possible to account for that:
(setq elwt
  (apply 'max
    (mapcar 'strlen
      (vl-remove nil (list HEADER THLBL JTLBL1 JTLBL2 JTLBL3 JTLBL4 JTLBL5 JTLBL6 JTLBL7 JTLBL8))
Kent Cooper, AIA
Message 6 of 8
it returns NIL
and yes there were some in the list that didn't have a value
I'm heading out now, so I'll take another look at it tomorrow
Thanks Kent
Message 7 of 8
vl-remove nil the answer!
Thank you again Kent
Message 8 of 8
john.uhden
I thought I had responded earlier, but this computer is *&^%$!$U&^*&^^%$^!!!
Anyway,
(vl-remove-if-not '(lambda (x)(= (type x) 'STR))(list ...))
  or
(vl-remove-if '(lambda (x)(/= (type x) 'STR))(list ...))
John F. Uhden
