get list of layer names based on description
dwattersAMXH5
Message 1 of 9
dwattersAMXH5
i am trying to build a lisp to vplayer  freeze layers based on their description
here is where i am now  -
(defun c:test2 (/ vpl ln ss en)
(vl-load-com)
(setq dsc '("testlayer" "testlayer2")) ; setting descriptions
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
(if (member (vla-get-description layer) dsc)
(setq layers '((vla-get-name layer)))
) ;trying to set layers to a list of layer names which descriptions match dsc
(setq ss (ssget "X" (list (cons 0 "VIEWPORT")
(cons 8 "viewport-titleblock")))) ; selecting viewport to run vplayer in
(= (sslength ss) 1)
(setq vp (ssname ss 0)) ;setting vp to the viewport name of the viewport that met selection criteria
(command "_.VPLAYER" "_Freeze" (member layers) "_S" vp "" "") ;trying to run vplayer, freeze, plug in list of layer names, set viewport to the one we want, enter, enter
(prin1)
my problem is that vplayer, freeze doesn't want to select the layer names from what i am trying to plug in.
any assistance on what i am doing wrong here?
Accepted solutions (3)
Replies (8)
Message 2 of 9
pbejse
Not deviating too much from your original code
(defun c:test2 (/ layers dsc ss)
(vl-load-com)
	(setq layers ""
	      dsc '("TESTLAYER" "TESTLAYER2"))
	 (if (member (Strcase (vla-get-description layer))  dsc)
	 	(setq layers (strcat (vla-get-name layer) "," layers))
	(if
	  (and
	    layers
	    (setq ss (ssget "X" '((0 . "VIEWPORT")(8 . "viewport-titleblock")(410 . "~Model"))))
	    (= (sslength ss) 1)
	 	(command "_.VPLAYER" "_Freeze" layers "_S" (ssname ss 0) "" "")
	(prin1)
HTH
Message 3 of 9
pbejse
should be
(setq ss (ssget "X" (list '(0 . "VIEWPORT")'(8 . "viewport-titleblock")(cons 410 (getvar 'ctab)))))
Message 4 of 9
Moshe-A
dwatters,
check this one.
enjoy
moshe
(vl-load-com)
(defun c:test2 (/ dsc LayLst^ LayTblRec ss n elist ename lay LayLst^)
 (setvar "tilemode" 0) ; switch to paper space
 (setq dsc "testlayer1,testlayer2") ; constant descriptions
 (setq LayLst^ '())
 (vlax-for LayTblRec (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
  (if (wcmatch (strcase (vla-get-description LayTblRec)) (strcase dsc))
   (setq LayLst^ (append LayLst^ (list (vla-get-name LayTblRec)))) ; create layer list
 ); vlax-for
 (if (setq ss (ssget "X" (list '(0 . "viewport") '(8 . "viewport-titleblock")))) ; select viewports
  (repeat (setq n (sslength ss))
   (setq elist (entget (setq ename (ssname ss (setq n (1- n))))))
   (if (> (cdr (assoc '69 elist)) 1) ; skip screen viewport
    (progn
     (if (/= (setq ctab (getvar "ctab")) (cdr (assoc '410 elist)))
      (setvar "ctab" (cdr (assoc '410 elist))) ; set layout
     (command "._mspace") ; enter model psace
     (setvar "cvport" (cdr (assoc '69 elist)))  ; set viewport
     ; freeze layers
     (foreach lay LayLst^
      (command "_.VPLAYER" "_Freeze" lay "_S" ename "" "")
     (command "._pspace") ; back to paper space
    ); progn
   ); if
  ); repeat
 ); if
 (princ)
Message 5 of 9
dwattersAMXH5
	(setq layers ""
	(if
	  (and
	    layers
	    (= (sslength ss) 1)
ran with this and it works great when there is only one viewport on the  "viewport-titleblock" layer when i copy the layout and have two viewports on "viewport-titleblock" layer it doesn't want to complete the lisp  (no errors or anything it just doesn't viewport freeze the layers) when i turn one of the viewports layers to 0 then re-run the lisp it works fine.
tried running something like this to make it run in each layout but that didn't really help the issue.
(vl-load-com)
(foreach layout (layoutlist)
 (setvar "ctab" layout)
	(setq layers ""
	 (if
	  (and
	    layers
	    (= (sslength ss) 1)
	(prin1)
Message 6 of 9
dlanorh
Your initial code contains the code line
(= (sslength ss) 1)
This indicates that you only want this to happen if there is only one viewport in the selection set. No where in your description does it mention anything about applying it across multiple viewports in the selection set. Both posted solutions run with this theme.
Perhaps a better description of what you are trying to do is required to obtain the solution you require.
I am not one of the robots you're looking for
Message 7 of 9
pbejse
As dlanorh already pointed out in the previous post
(= (sslength ss) 1)
Below are two modified routines to process more than 1 layout tab
One viewport per layout
(defun c:test219 (/ layers dsc ss i ent e)
(vl-load-com)
	(setq layers ""
	(if
	  (and
	    layers
	  (repeat (setq i (sslength ss))
	    	(setq ent (entget (setq e (ssname ss (setq i (1- i))))))
	    	(if (/= (setq thistab (cdr (assoc 410 ent))) (getvar 'ctab))
		  	(setvar 'ctab thistab)
	 	(command "_.VPLAYER" "_Freeze" layers "_S" e "" "")
	(princ)
Multiple layouts and viewports
(defun c:test423 (/ layers dsc ss i ent e)
(vl-load-com)
	(setq layers ""
  (foreach lay (layoutlist)
	(if
	  (and
	    layers
				      (cons 410 lay))))
	  (progn
	    (setvar 'ctab lay)
	(princ)
For both routines, it will switch layout tab only if there are valid viewports found.
HTH
Message 8 of 9
dwattersAMXH5
I know my original post didn’t state that, this was an after thought to better understand what was making it behave that way, I’ve just started trying to write my own lisps after having been using ones I found on this forum for about a year extensively, I oviusly just know enough at this point to get myself in trouble with it, and I do try to search extensively for similar case situations to find what I can’t figure out before making a post.
I wasn’t trying to say anyone’s code didn’t work, they all did and were a huge help for part of the lisp I am trying to work through.
But Thanks for your concerns about my post descriptions.
Message 9 of 9
dwattersAMXH5
Thank you both for explaining sslength a little better for me( still working through multiple Udemy courses on Lisps).
I will run this later and see what the results are but I’m sure it’s perfect as every other bit of code you posted has been!
Thank you, and everyone else so much for all the help.
