get Layer name and Colour from selected object
jyan2000
jyan2000
Dear All,
How do I get Layer name and Colour from selected object as a text shown in attached file.
Best Regards
Victor.
BlackBox_
Here's a starting point:
(defun c:FOO (/ e)
  (if
    (and
      (setq e (car (entsel "\nSelect entity for layer name, and color: ")))
      (setq e (tblsearch "layer" (cdr (assoc 8 (entget e)))))
     (prompt
       (strcat
         "\nLayer: "
         (cdr (assoc 2 e))
         ", Color: "
         (itoa (cdr (assoc 62 e)))
  (princ)
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Not sure if this helps but I've been able to get the layer name but all I can get is the index color for each layer.
(vl-load-com)
(defun C:Test3 ()
  (setq nwent (entsel))
  (if nwent
    (progn
      (setq nwen(car nwent))
      (setq nwelist (entget nwen))
      (setq layername (cdr (assoc 8 nwelist)))
      (setq obj (vlax-ename->vla-object (car nwent)))
      (setq layerinfo (tblsearch "layer" layername))
      (setq layercolor (cdr (assoc 62 layerinfo)))
    (alert "Nothing Selected")
  (prompt "\n")
  (princ "layername : ")
  (princ layername)
  (prompt "\n")
  (prompt "\n")
  (princ "layercolor : ")
  (princ layercolor)
  (prompt "\n")
  (princ)
BlackBox_
(vl-load-com)
(defun C:Test3 ()
  (if nwent
    (progn
  (prompt "\n")
  (princ layername)
  (prompt "\n")
  (prompt "\n")
  (princ layercolor)
  (prompt "\n")
  (princ)
Try:
(defun c:FOO (/ e layerName oLayer oTrueColor)
  (if
    (prompt
      (strcat
        "\nLayer: "
        (setq layerName (cdr (assoc 8 (entget e))))
        ", Color: "
        (itoa (vla-get-color
                (setq oLayer
                       (vla-item
                         (vla-get-layers
                           (vla-get-activedocument (vlax-get-acad-object))
                         layerName
        ", True Color (RGB): "
        (itoa (vla-get-red (setq oTrueColor (vla-get-truecolor oLayer)))
        (itoa (vla-get-green oTrueColor))
        (itoa (vla-get-blue oTrueColor))
  (princ)
jyan2000
Thank you Black Box, That's great . but is it possible to indicate with a text?
