Get height of block
Get height of block
erichter
Get height of block
erichter
Hey all! I have a script that pulls exported .dxf files from a Windows folder and batch inserts them into AutoCAD as blocks stacked vertically in the -Y direction. This script works great except that I have to guess the spacing increment and do some ctrl-z trial and error.
Is it possible to get the local max Y coordinate of the last inserted block, like with like (ssname (ssget "_L") 0), so that I can move the last inserted block based on that value?
(defun c:BI ( / DPATH DWGLST I MSG PT)
(vl-load-com)
(vla-StartUndoMark (setq *DOC* (vla-get-ActiveDocument (vlax-get-acad-object))))
(if (and (setq dpath (getfiled "Open a file in the DXF folder" (strcat (getenv "userprofile") "/Documents/") "" 8))
(setq i (getreal "\nEnter vertical spacing: "))
);; and
(progn
(setq
dpath (substr dpath 1 (- (strlen dpath) (vl-string-search "\\" (vl-list->string (reverse (vl-string->list dpath))))))
dxflst (vl-directory-files dpath "*.dxf" 1)
pt '(0. 0. 0.)
(foreach dxf dxflst
(command ".-insert" (strcat dpath dxf) pt "" "" "")
(setq
pt (list 0. (- (cadr pt) i) 0.)
);; foreach
);; progn
);; if
(princ)
(vla-EndUndoMark *DOC*)
Kent1Cooper
@erichter wrote:
Is it possible to get the local max Y coordinate of the last inserted block, ... so that I can move the last inserted block based on that value?
You may be able to use the approach in my BlockChart routines, >here<.  Are you knowledgeable enough to incorporate their spacing elements into your other routine?
Kent Cooper, AIA
erichter
This is it. Thanks! Your routine pretty much does the same thing as mine except it has the automatic spacing I was looking for, so I won't have any issue incorporating it.
