Get Basic Block Name In AutoLisp - How?
brewnot
brewnot
I want to create a simple AutoLisp routine to update a blocks, regular and dynamic. Here is the outline of steps.
Start command
Select block, gets [apparent block name]
-insert, [apparent block name]= (redefines block from library)
Cancel insert command
Attsync, Name, [apparent block name]
Close command
I hit the show stopper when selecting a block. If it is a dynamic block, the name returned is the temp name. E.g. *U143. I know there is a method to pick a block and get the base block name and not the *U143 name.
I have been searching the google webs and this forum, but nothing comes back that my pea sized AutoLisp knowledge bank can sort out.
I will be grateful for any help.
Ranjit_Singh
Maybe like this
(vla-get-effectivename (vlax-ename->vla-object (car (entsel "\nSelect block: "))))
brewnot
I have seen that, but I am missing something. what is the next step?
-insert XXXX=  (stop insert command)
What do I put in place of XXXX?
Kent1Cooper
You could wrap that getting-the-effective-name code into a (setq) function to put it into a variable:
(setq bname (vla-get-effectivename (vlax-ename->vla-object (car (entsel "\nSelect block: ")))))
and then use that variable in appropriate places later, such as:
(command "_.insert" (strcat bname "=") nil)
EDIT:  I had the "_yes" answer in there for confirming that I wanted it redefined, but apparently it doesn't ask that from within a (command) function.
Kent Cooper, AIA
Ranjit_Singh
XXX is the name of your redefined block. You have to pick that name. Something like this
(setq new_bl_name "New_test_block")
(setq input (strcat new_bl_name
                    (vla-get-effectivename (vlax-ename->vla-object (car (entsel "\nSelect block to redefine: "))))))
brewnot
Here is what I ended up with.
(defun c:blup-07 (/ bname)
(princ "\nSelect Block To Update: ")
(command "_.attsync" "name" (strcat bname))
(princ))
Works like a charm. Has not failed me yet. Thanks to everybody for the help.
