Get and Sort Polyline Start and End Coordinates
codyhornyak
codyhornyak
I am working on a LISP to get and sort polyline start and end coordinates. This is what I have so far. Line 7 is giving me issues. How should I change this?
(defun C:PLINESELSET
  (/ ssMessenger i vlaObject points alldata_plines)
  (setq ssMessenger (ssget "x" '(0 . "LINE,*LWPOLYLINE")))
  (repeat (setq i (sslength ssMessenger)) ; repeat for each line found
    (setq vlaObject (vlax-ename->vla-object (ssname ssMessenger (setq i (1 - i)))))
    (setq points (vlax-get-property vlaObject 'coordinates)) ; get coordinates
    (setq alldata_plines
      (cons
        (list points)))
  ) ; repeat
  (print alldata_plines)
) ; defun PLINESELSET
One I get the start and end coordinates of a single polyline, they should be sorted from west to east. Then, once there is a list of all the polyline coordinates in the drawing, they should be sorted from north to south. For example:
PLINE 1 from (0,0) to (1,0)
PLINE 2 from (1,1) to (-1,1)
First, sort each coordinate pair from west to east:
PLINE 1: (0,0) to (1,0)
PLINE 2: (-1,1) to (1,1)
Then, sort each coordinate pair from north to south(can just use y-coordinate of the first coordinate in the pair:
Hopefully this question makes sense. Thanks.
ВeekeeCZ
Here you are. Note that
* got start and end points
* made a list of these two
* sorted lst of them by X
* added a sorted lst to the overall lst
* sorted the overall lst by Y.
(defun c:Plinesort ( / s i e l)
  (if (setq s (ssget '((0 . "LWPOLYLINE,LINE"))))
    (repeat (setq i (sslength s))
      (setq e (ssname s (setq i (1- i)))
	    l (cons (vl-sort (list (vlax-curve-getstartpoint e) (vlax-curve-getendpoint e))
			     '(lambda (e1 e2) (< (car e1) (car e2))))
		    l))))
  (vl-sort l '(lambda (e1 e2) (> (cadar e1) (cadar e2))))
  (print l)
  (princ)
*LWPOLYLINE does not make sense. it should be *POLYLINE
To build a list, use (setq l (cons item l)). In this case, it should be (setq l (cons (list startpt endpt) l).
I think I already linked this to you... Need to be familiar with THIS  group of CURVE functions.
codyhornyak
Thanks a bunch @ВeekeeCZ . I am learning, its just taking time. I have this LISP wrapped up for now, moving onto the next one shortly.
JBerns
@codyhornyak
Congrats on your efforts and success.
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
calderg1000
Regards @codyhornyak
Try this code
Sort the coordinates of lines or polylines, from East to West and from North to South.
(defun C:Plset (/ ssMessenger i vlaObject points)
  (setq ssMessenger (ssget "_+.:E:S" '((0 . "LINE,LWPOLYLINE")))
        vlaObject   (vlax-ename->vla-object (ssname ssMessenger 0))
  (if (not (= (vla-get-Objectname vlaObject) "AcDbLine"))
    (progn
      (setq points (vlax-get vlaObject 'coordinates) ; get coordinates
            lf     (pts2 points)
    (progn
      (setq lf (list (vlax-get vlaObject 'startpoint)
                     (vlax-get vlaObject 'endpoint)
  (print (setq lf_e (vl-sort lf '(lambda (e1 e2) (< (car e1) (car e2))))))
                                                  ;Points, sorted by Easting-West coordinate
  (print (setq lf_n (vl-sort lf '(lambda (e1 e2) (> (cadr e1) (cadr e2))))))
                                                  ;Points, sorted by Norting-Sur coordinate
  (princ)
(defun pts2 (lp)
  (if lp
    (cons
      (setq lpt (list (nth 0 lp) (nth 1 lp)))
      (pts2 (cddr lp))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
