Get an angle from a Block.
My problem is that I need to get an angle from a Block.
But instead to get the angle that I have in my personal UCS, it gets the angle that I I have at UCS - World.
I need the angle in my personal UCS, I hope someone could help me.
Thanks in advance.
The routine is this
(defun getAngleBlock (/)
  (setq ent (entsel "\nPunto para conectar el codo:\n"))
  (setq ent (entget (car ent)))
  (setq rot_bloque (cdr (assoc 50 ent)))
  (prompt (strcat "\nThe angle obtained was this:" (angtos rot_bloque 0 4)))
  (prin1)
(defun c:GA (/)
  (getAngleBlock)
And the block is attached.
elshawadfy
The modified code included  finds the angle of current x axis (arctan x,y of the current x axis stored in the "UCSXDIR" system variable), and then substracts it from the object anle stored in its properties to calculate the current angle according to current ucs..
(defun getAngleBlock (/ ent rot_bloque)
  (setq rot_bloque (- rot_bloque (atan (/ (car (getvar "UCSXDIR")) (cadr (getvar "UCSXDIR")) ))))
  (prin1)
(defun c:GA (/)
  (getAngleBlock)
stevor
May want to use the 'atan function with 2 arguments,
instead of a single that has the division,
to avoid the possible divide by zero.
S
elshawadfy
Thank you very much Stevor!!
Yes you're wright.. That would be the correct apprauch..
