Get all available properties
jtm2020hyo
jtm2020hyo
I am learning to write lisp, but I have some questions:
How to get all available properties for autolisp and visual lisp in a list, for AutoCAD Vanilla, Civil 3D, AutoCAD MEP or any AutoCAD vertical?
Maybe with vlax-dump-object and anything more?
Accepted solutions (4)
Kent1Cooper
There's another set of Properties for the (getpropertyvalue)/(setpropertyvalue) world [some have the same names, some are not in the VLA properties listing and vice versa, and some are in both but with different names]:
(dumpallproperties EntityName)
Kent Cooper, AIA
john.uhden
@jtm2020hyo ,
@Kent1Cooper gave you excellent advice (as he always does), but it dumps only to the screen.
I had posted an extruded way to write the info to a file, but I can't find it now.  Maybe someone else can.
John F. Uhden
paullimapa
attached is a modified version of @Kent1Cooper
instead of listing the object to a text file vlax-dump-object function is used
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/exracting-list-properties-of-objects...
Paul Li
IT Specialist
@The Office
Sea-Haven
Use dumpit.lsp press F2 then just copy and paste to notepad, how many times do you really need to remember all the values, I just copy the relevant property names into code so dont get typo's.
