Generate numbered variables in loop
DC-MWA
Message 1 of 10
DC-MWA
Hi all,
I'm looking to make lists of variable values in a loop.
Each pass i need to create a new list as follows:
(setq 1-2 (list A B C))
(setq 2-3 (list A B C))
(setq 3-4 (list A B C))
(setq 4-5 (list A B C))
;end loop
Then gather all new lists,  example(1-2, 2-3, 3-4, 4-5)
so basically add 1 to each number on each side of "-"
I hope that makes sense.
Replies (9)
Message 2 of 10
DC-MWA
I figured it out.
Message 3 of 10
devitg
please , show us how did you figured it out
Message 4 of 10
pbejse
I'm more interested on why the need for that format.
Do you mind telling us @DC-MWA  ?
Message 5 of 10
DC-MWA
I ended up doing this (I'm sure this is long and drawn out, I'm no programmer by any means)
(setq bt-n 0);;start count for lists
(setq bt-n2 1);;start count for lists
(while
;;program gathers data and puts in variables
(setq bt-n (1+ bt-n))<-- Increment variable in loop
(setq bt-n2 (1+ bt-n2))<-- Increment variable in loop
(setq x_list (list (strcat (itoa bt-n) "_" (itoa bt-n2)) (/ slen 12) (/ d1 12) (/ d2 12)))
(setq master_list (append (list x_list) master_list))
(setq master_list_rev (reverse master_list))
);end while
;;produces
((1_2 150.0 30.0 25.0) (2_3 150.0 30.0 30.0) (3_4 50.0 15.0 15.0) (4_5 80.0 160.0 160.0) (5_6 100.0 95.0 95.0) (6_7 70.0 60.0 60.0))
Message 6 of 10
DC-MWA
I'm looking to export the information to an excel file.
Each list represents data between two points...
1_2 is the information between 1 and 2
2_3 is the information between 2 and 3
Then the "master list" gathers all the lists:
the points are taken around a building outline.
Message 7 of 10
_gile
What are slen, d1, d2?
If you do not give more precisions about ALL inputs, it will be difficult to help you.
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
DC-MWA
slen = segment length
d1 = distance 1
d2 = distance 2
Message 9 of 10
Sea-Haven
If you want decimal answer (/ slen 12.0)
Message 10 of 10
martti.halminen
Well, you just managed to create an eternal loop.
- not quite eternal, probably crashes when it runs out of memory.
Where is your test expression telling when to stop the WHILE loop?
- This doesn't work quite like you claim to intend, produces something like
(("1337_1338" 4 2 2) ("1336_1337" 4 2 2) ("1335_1336" 4 2 2) ("1334_1335" 4 2 2)) i.e. the first item is a string, not a symbol.
- not necessarily a problem, can be used this way too.
One style hint:
is unnecessarily inefficient.
(cons x_list master_list)
would produce the same end result but less garbage.
Generally, APPEND gets far too much mindshare in teaching Lisp, in real life it is not needed all that much.
- I am working here with a directory containing 97000 lines of AutoLISP code. There are only 12 calls to APPEND in that program.
