garbing DWG file name and save the new files as same layout name
mohamad-alimam
mohamad-alimam
hello
I am trying to export from one AutoCAD file layout sheet to separate dwg file the problem is, I am trying to make a try to save the new file without marge dwg file with layout name I want the only layout file name the forums:
(defun c:exportmodelspace ( / BASE LST OLD_DIA)
(setq old_dia (getvar 'FILEDIA)
base (strcat (getvar 'DWGPREFIX) (vl-filename-base (getvar 'DWGNAME)))
(setvar 'FILEDIA 0)
(setq lst (layoutlist))
(foreach l lst
(command "_.ctab"
l
"exportlayout"
(strcat base "-" l)
(setvar 'FILEDIA old_dia)
(princ)
devitg
it work ok for me
mohamad-alimam
 Thank you for your trying
it works like the old same what I need is only export layout to dwg and have only layout name without dwg name
pbejse
(defun c:exportmodelspace (/ base lst old_dia)
  (setq old_dia (getvar 'filedia))
  (setvar 'filedia 0)
  (foreach l lst
    (command "_.ctab" l "exportlayout" (strcat (getvar 'dwgprefix) l))
  (setvar 'filedia old_dia)
  (princ)
