Function Not Seeing Special Character In String
DGCSCAD
DGCSCAD
For some reason when I run a function containing this code fragment:
(setq istest (wcmatch str_list3 "*Â*"))
Using this string (str_list3): "TEST®"
...it's coming back NIL, but when I paste that same code fragment to the command line with everything else in place, it returns T.
Everything else around it is working as it should be, so I'm guessing the LISP interpreter uses a different character set than the AutoCAD API for the command line...?
AutoCad 2018 (full)
Win 11 Pro
pbejse
Its coming out T however i run that snippet, can you give us more info?
paullimapa
what happens if you precede with `
(wcmatch str_list3 "*`Â*")
Paul Li
IT Specialist
@The Office
komondormrex
try to use unicode notation in (setq istest (wcmatch str_list3 "*\U+00c2*")) for "Â" char.
DGCSCAD
Still returns NIL.
AutoCad 2018 (full)
Win 11 Pro
DGCSCAD
That worked! Thank you!
AutoCad 2018 (full)
Win 11 Pro
