Fun time with speak function
Message 1 of 15
Hi guys... I have found thread over at Swamp for integrating SPEAK function into ACAD.
http://www.theswamp.org/index.php?topic=14549.75
I am trying to make it work but my skills are still quite poor.
I would like to make acad say Kaboom when I explode ...
I did this simple code but it is not really synchronized 🙂 it works , but tone is too low and it says "Kaboom" before i actualy select and explode object.
(defun C:exx () (command "explode")
(setq sapi (vlax-create-object "Sapi.SpVoice"))
(vlax-invoke sapi "Speak" "Kaboom" 0)
(vlax-release-object sapi))
I would like to see principle , to have simple function that after it is done says something or even better play a sound. Also I would need to have volume up.
Jan
Replies (14)
Message 2 of 15
Kent1Cooper
@Anonymous wrote:
.... it says "Kaboom" before i actualy select and explode object.
As to that issue only, you would need to let the Explode command be completed before moving on to the Speak part.
  ....  (command "_.explode")
  (while (> (getvar 'cmdactive) 0) (command pause))
  (setq ....
Kent Cooper, AIA
Message 3 of 15
THX Kent...
Message 4 of 15
Kent1Cooper
@Kent1Cooper wrote:
.... you would need to let the Explode command be completed before moving on to the Speak part.
  (setq ....
Come to think of it, since Explode in a (command) function can work with only one object at a time [unless you go through some hoops -- Search here for QAFLAGS], you could probably do it more simply:
(defun C:exx () (command "explode" pause)
(setq sapi ....
Kent Cooper, AIA
Message 5 of 15
DGCSCAD
My apologies for digging up an old thread...
I've used this for quite a while now, but I'm on a new system and I get a "Class not registered" error.
(vl-load-com)
(setq speak (vlax-create-object "Sapi.SpVoice.1"))
(vlax-invoke speak "Speak" "I am sorry Dave I can not allow you to do that" 0)
(vlax-release-object speak)
Sapi.SpVoice and Sapi.SpVoice.1 are both in the registry so I'm not sure whats going on.
Any ideas?
AutoCad 2018 (full)
Win 11 Pro
Message 6 of 15
pendean
Community Legend
Community Legend
@DGCSCAD wrote:
I've used this for quite a while now, but I'm on a new system and I get a "Class not registered error".
Share a full screenshot of that error the program it popped up in so we can all understand the context better please.
Message 7 of 15
DGCSCAD
(defun c:speak ( / speak)
(vl-load-com)
(setq speak (vlax-create-object "Sapi.SpVoice"))
Command: speak
; error: Class not registered
Command:
AutoCad 2018 (full)
Win 11 Pro
Message 8 of 15
Sea-Haven
Maybe some extra switches.
(defun SpeakSapi ( s / sapi )
(if (eq (type s) 'STR)
(progn
(vlax-put sapi 'SynchronousSpeakTimeout 1)
(vlax-invoke-method sapi 'WaitUntilDone 0)
(vlax-invoke sapi "Speak" s 0)
(speaksapi "Happy Birthday from AL thank you for your on-going help")
Message 9 of 15
DGCSCAD
(progn
I appreciate the help. Still getting the error tho.
Command: (load"speak")
SPEAKSAPI
Command: (speaksapi "Happy Birthday from AL thank you for your on-going help")
Error: Class not registered
bad argument type: VLA-OBJECT nil
I even threw a (vl-load-com) in there to make sure.
AutoCad 2018 (full)
Win 11 Pro
Message 10 of 15
pendean
Community Legend
Community Legend
SPEAKSAPI
Confirm you are NOT using the LT versions of AutoCAD please (2024/2025).
Message 11 of 15
DGCSCAD
@pendean wrote:
SPEAKSAPI
My apologies, here's my setup:
AutoCad 2018 (full)
Win 10 Pro
AutoCad 2018 (full)
Win 11 Pro
Message 12 of 15
Sea-Haven
#<VLA-OBJECT ISpeechVoice 0000000023C93880>
: (setq s "test message")
"test message"
: (vlax-invoke sapi "Speak" s 0)
1
Message was heard.
Pretty sure worked with 2018.
Do the following and copy 1  at a time to command line
if no error message
(setq s "Test message")
let us know where error occurs.
Message 13 of 15
vladimir_michl
Are you using some non-EN version of Windows? You may need to install the voice support for "non-standard" languages. Also make sure the SAPI.SpVoice support is properly registered - usually in this DLL:
%SystemRoot%\System32\Speech\Common\sapi.dll
(so perform a regsvr32 on it)
BTW, you can use the voice output even in AutoCAD LT - see https://www.cadforum.cz/en/workaround-for-the-missing-vlax-create-object-in-autocad-lt-tip14007
Vladimir Michl, www.arkance-systems.cz  -  www.cadforum.cz
Message 14 of 15
DGCSCAD
@Sea-Haven
After restarting AutoCad and running each line of your post separately at the command line, it's working. Thank you for the nudge. It seems like lately I've been posting up questions to problems I'm having without fully exhausting all possibilities of what could be wrong. Thanks for bearing with me and taking the time to walk me through it. Some days I'm just "off" by about >< that much. lol
@vladimir_michl
Good to know.
AutoCad 2018 (full)
Win 11 Pro
Message 15 of 15
Sea-Haven
Sometimes I find I have to close and restart CAD as it seems to get stuck in a loop and not update correctly particularly when repeatedly trying code. I do a lot of copy and paste when writing code and that may the problem.
