from points to groups of points
Moshe-A
Mentor Mentor
Message 1 of 10
Moshe-A
Dear Experts,
Have a difficulty to finish >> this thread <<  and i'm asking for your help.
bellow is the code i have so far... variable 'cross' is a list collecting all intersect points. what i need is functions to return a list with groups of points in this format:
        grp0               grp1                       grp2
( ((x y z))  ((x y z) (x y z))  ((x y z) (x y z) (x y z)) ........)
in a group all points must fall in < cmrk-fazz (a variable in program) from each other.
in >> this thread <<  you will find more info you need including a sample dwg to test.
thanks in advance
Moshe
(defun c:cmrk (/ askreal is_intersect double->lst ; local functions
                 CMRK-FUZZ ss data ename0 ename1 pline0 pline1 rgn1 rgnUnion doubles points)
 (defun askreal (def)
  (initget 4)
  (if (not (setq ask (getreal (strcat "\ncmrk-fuzz <" (rtos def 2) ">: "))))
   (setq ask def)
   (setq def ask)
 ); askreal
 (defun is_intersect (o0 o1 / r)
  (if
   (not
     (vl-catch-all-error-p
       (setq r (vl-catch-all-apply 'vlax-invoke (list o0 'IntersectWith o1 acExtendNone)))
   r
 ); is_intersect
 (defun double->lst (doubles / _index i lst)
  (setq _index (lambda (b inc) (+ (* b 3) inc)))
  (setq i -1)
  (repeat (/ (length doubles) 3)
   (setq i (1+ i))
   (setq lst (cons (list (nth (_index i 0) doubles) (nth (_index i 1) doubles) (nth (_index i 2) doubles)) lst))
  lst
 ); double->lst
 ; here start c:cmrk
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (setq cross nil)
 (if (= (getvar "userr1") 0)
  (setq def-fuzz (setvar "userr1" 1e-2))
  (setq def-fuzz (getvar "userr1"))
 (if (and
       (setvar "userr1" (setq cmrk-fuzz (askreal def-fuzz)))
       (setq ss (ssget '((0 . "lwpolyline") (70 . 1)))) ; select closed polylines
  (progn
   (setq data (mapcar '(lambda (ename) ename) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
   (foreach ename0 (reverse (cdr (reverse data)))
    (setq pline0 (vlax-ename->vla-object ename0))
    (foreach ename1 (cdr (member ename0 data))
     (setq pline1 (vlax-ename->vla-object ename1))
     (if (setq doubles (is_intersect pline0 pline1))
      (progn
       (command ".region" "_si" (vlax-vla-object->ename (vla-copy pline0)))
       (setq rgn0 (entlast))
       (command ".region" "_si" (vlax-vla-object->ename (vla-copy pline1)))
       (setq rgn1 (entlast))
       (command "._union" rgn0 rgn1 "")
       (setq rgnUnion (vlax-ename->vla-object (entlast)))
       (if (and
             (not (equal (vla-get-area rgnUnion) (+ (vlax-curve-getarea pline0) (vlax-curve-getarea pline1)) 0.0))
             (setq points (double->lst doubles))
        (setq cross (append cross points))
       ); if
       (vla-delete rgnUnion)
       (vlax-release-object rgnUnion)
      ); progn
     ); if
     (vlax-release-object pline1)
    ); foreach
    (vlax-release-object pline0)
   ); foreach
  ); progn
 ); if
 (command "._undo" "_end")
 (princ)
); c:cmrk
Replies (9)
Message 2 of 10
CodeDing
@Moshe-A ,
I did not test with all of your other stuff, but based on your description, I think this will accomplish what you are asking for. Maybe you can refine it further, worth a try.
;; ptList - list, of points
;; cmrk-fazz - int/real, of "fuzz" distance
;; returns - list, of 'grouped' points determined by "fuzz" factor
(defun GroupByFazz (ptList cmrk-fazz / grpList grpRemove first)
  (while ptList
    (if (> (length ptList) 1)
      (setq grpList
        (cons
          (setq grpRemove
            (cons
              (setq first (car ptList))
              (vl-remove-if-not
                '(lambda (pt) (< (distance first pt) cmrk-fazz))
                (cdr ptList)
              );vl
            );cons
          );setq
          grpList
        );cons
      );setq
    ;else
      (setq grpList (cons (setq grpRemove ptList) grpList))
    );if
    (foreach pt grpRemove
      (setq ptList (subst nil pt ptList))
    );foreach
    (setq ptList (vl-remove-if 'null ptList))
  );while
  grpList
);defun
Best,
~DD
Message 3 of 10
ronjonp
Here is another for fun 🍻 (edit refactored '_groupbyfuzz ' as subfunction)
(defun c:foo (/ _int _groupbyfuzz a b f r s)
  ;; RJP » 2021-03-16
  (defun _int (o1 o2 / p r)
    (if	(= 'list (type (setq p (vl-catch-all-apply 'vlax-invoke (list o1 'intersectwith o2 0)))))
      (repeat (/ (length p) 3) (setq r (cons (mapcar '+ p '(0 0 0)) r)) (setq p (cdddr p)))
    r
  (defun _groupbyfuzz (l f / a b r)
    (while (car l)
      (setq a (car l))
      (setq b (vl-remove-if-not '(lambda (x) (equal a x f)) l))
      (foreach c (append (list a) b) (setq l (vl-remove c l)))
      (setq r (cons b r))
    r
  (cond
    ((and (setq s (ssget '((0 . "~INSERT"))))
	  (setq f (getdist "\nPick fuzz distance: "))
	  (setq s (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))))
     ;; Gather intersection points in 'r'
     (while (cadr s)
       (setq a (car s))
       (foreach p (setq s (cdr s)) (and (setq b (_int a p)) (setq r (cons b r))))
     ;; Append the list of lists and group by a fuzz value in 'r'
     (setq r (_groupbyfuzz (apply 'append r) f))
     ;; List of grouped points
     r
  (princ)
Message 4 of 10
ВeekeeCZ
Question. How many groups are on the picture if fuzz is 1. Is it one or two?
BTW THIS  task is the pretty much about it too.
Message 5 of 10
ronjonp
@ВeekeeCZ  I say one if you sort it correctly 😎
(defun c:foo2 (/ _int _ap _groupbyfuzz2 a b c d f r r2 s)
  ;; RJP » 2021-03-17
    r
  (defun _ap (l / r)
    (setq r '(0 0 0))
    (foreach p l (setq r (mapcar '+ p r)))
    (mapcar '/ r (list (length l) (length l) (length l)))
  (defun _groupbyfuzz2 (l f / a b c r)
    (while (car l)
      (setq a (car l))
      (setq b (vl-remove-if-not '(lambda (x) (equal a x (* f 2.))) l))
      (setq c (_ap b))
      (setq b (vl-sort b '(lambda (r j) (< (distance c r) (distance c j)))))
      (setq r (cons (setq b (vl-remove-if-not '(lambda (x) (equal (car b) x f)) b)) r))
      (foreach p b (setq l (vl-remove p l)))
    r
  (cond
     (while (cadr s)
       (setq a (car s))
     (setq r (_groupbyfuzz2 (apply 'append r) f))
     r
  (princ)
Message 6 of 10
Moshe-A
@ronjonp   +   @CodeDing
well well guys 😀, both programs works splendid
ronjonp your is extraordinary short and efficient.
thank you very much
Moshe
Message 7 of 10
ronjonp
@Moshe-A  Glad to help 🙂 .. did you try the 'foo2' variant?
Message 8 of 10
Moshe-A
i used only (_groupbyfuzz)
Message 9 of 10
ronjonp
@Moshe-A
This one should create less groups.
Message 10 of 10
CodeDing
I tried to take some pointers from @ronjonp  😅
I have no ide if this would be fast or slow. Just seemed fun to try.
(defun GroupByFazz (ptList cmrk-fazz / len ptAvg grpList first)
  (while (and ptList
              (setq len (length ptList))
              (setq ptAvg
                (mapcar
                  '(lambda (n) (/ n len))
                  (mapcar
                    '(lambda (f) (apply '+ (mapcar f ptList)))
                    '(car cadr caddr)
                  );mapcar
                );mapcar
              );setq
              (setq ptList
                (vl-sort
                  ptList
                  '(lambda (a b) (< (distance ptAvg a) (distance ptAvg b)))
                );vl-sort
              );setq
         );and
    (setq grpList
      (cons
        (mapcar
          '(lambda (ptR) (setq ptList (vl-remove ptR ptList)) ptR)
          (cons
            (vl-remove-if-not
              '(lambda (pt) (equal first pt cmrk-fazz))
              (cdr ptList)
            );vl
          );cons
        );mapcar
        grpList
      );cons
    );setq
  );while
  grpList
);defun
Best,
~DD
