freeze objects
freeze objects
michaelZCXYL
Message 1 of 34
freeze objects
michaelZCXYL
I am wondering if it is possible to freeze/off objects instead off freeze/off layers? thank you  very much in advance.
Replies (33)
Message 2 of 34
cadffm
Message 3 of 34
Kent1Cooper
As suggested, HIDEOBJECTS makes things disappear, but only in a temporary way.  It does not survive closing the drawing -- when you open it again, the object(s) will be visible again.  If you are looking for something that hides them permanently until you choose to see them again, I don't know of anything other than the Layer-based approach.
Kent Cooper, AIA
Message 4 of 34
michaelZCXYL
I am looking for something that hides them permanently, "hide" command just temporarily do it, many thanks.
Message 5 of 34
cadffm
ISOLATE can hide object longer,but it is a setup question (and I prefer to set it to REFERESH by  every open)
OBJECTISOLATIONMODE
That's all in plain AutoCAD/LT
Sebastian
Message 6 of 34
pendean
Community Legend
Community Legend
That would be ERASE command then.
Otherwise... How would you know a day/two/month/year later that those are still in the file when you need them back?
Message 7 of 34
Kent1Cooper
OBJECTISOLATIONMODE ....
I wasn't aware of that one [a new possibility in more recent versions, I assume].  @pendean, with it set to 1, UNISOLATEOBJECTS would still bring everything back to viewable, but I assume you wouldn't know in a later session whether there were things to reveal without using that to find out.  BUT there's the complication that it's Saved in User Settings, not in each drawing -- @michaelZCXYL, does that mean it wouldn't serve your purpose?
Kent Cooper, AIA
Message 8 of 34
john.uhden
@michaelZCXYL
I once recently ran into a similar problem.
I could have changed the selection to a "HIDDEN" layer, but that would have changed their inherited "bylayer" properties.  So I decided to make them invisible with the option to make them all visible again or just report and show the grips of the invisible ones.  It includes Undo control...
(defun C:Visible ( / *error* vars vals ss E Obj i N)
  ;; v1.0 (8-31-21) John F. Uhden
  ;; Program makes each entity in a selection set invisible, or
  ;; Makes all invisible objects visible, and
  ;; Has a Report option to inform of the number of invisible objects.
  (gc)
  (prompt "\nVisible v1.0 (c)2021, John F. Uhden\n")
  (defun *error* (Error)
    (mapcar 'setvar vars vals)
    (vla-endundomark *doc*)
    (cond
      ((not Error))
      ((wcmatch (strcase Error) "*QUIT*,*CANCEL*")
         (vl-exit-with-error "\r                                              ")
      ((wcmatch (strcase Error) "*CANCEL*,*QUIT*")
         (vl-exit-with-error (strcat "\r*ERROR*: " Error))
    (princ)
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
  (vla-startundomark *doc*)
  (setq vars '("cmdecho"))
  (setq vals (mapcar 'getvar vars))
  (mapcar 'setvar vars '(0))
  (command "_.expert" (getvar "expert")) ;; dummy command
  (initget 1 "INvisible iNvisible Report Visible")
  (setq ans (getkword "\nMake selected objects iNvisible/Visible/Report: "))
  (cond
    ((= ans "Report")
      (setq ss (ssget "x" '((60 . 1))))
      (setq N (sslength ss))
      (princ (strcat "\nFound " (itoa N) " invisible entities."))
      (sssetfirst nil ss)
    ((= ans "Visible")
      (princ "\nAll invisible objects will be made visible.")
      (getstring "\nHit any key to continue, or Esc to stop.")
      (repeat (setq i (sslength ss))
        (setq e (ssname ss (setq i (1- i)))
            obj (vlax-ename->vla-object e)
        (vlax-put obj 'Visible -1)
      (princ (strcat "\n  Made " (itoa (sslength ss)) " objects visible."))
    (1
      (princ "\nSelect objects to make invisible.")
      (setq ss (ssget))
        (vlax-put obj 'Visible 0)
      (princ (strcat "\n  Made " (itoa (sslength ss)) " objects invisible."))
  (*error* nil)
(defun c:VIS ()(c:Visible))
John F. Uhden
Message 9 of 34
michaelZCXYL
Thank you  very much all of you. I want to freeze or off object like freeze/off layer, I can bring them when need. If using isolating object, they can be hide longer. But when using this command later, ending isolation session, they will come back if I do not want see them, thanks again. 🙂
Message 10 of 34
cadffm
You need a Tool to do that,
based on the technic of Johns code.
There are many available, just test and find your favorite.
Nothing ootb in vanilla AutoCAD.
Sebastian
Message 11 of 34
michaelZCXYL
Could you please advise me where I can find them? Also, I need another tool, to move revision clouds to new layers, thank you very much. 🙂
Message 12 of 34
michaelZCXYL
For many drawings
Message 13 of 34
pendean
Community Legend
Community Legend
For many drawings
See your other post, no need to ask for the same thing in different posts all over these forums
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/run-lisp-script-or-macros-to-select-...
Message 14 of 34
michaelZCXYL
noted and thanks
Message 15 of 34
ronjonp
@michaelZCXYL
Try this ... regen to make visible again.
(defun c:foo (/ s)
  (if (setq s (ssget))
    (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (redraw e 2))
  (princ)
Message 16 of 34
Kent1Cooper
@ronjonp wrote:
Try this ... regen to make visible again. ....
That has the same problem as doing it with the HIDEOBJECTS command -- it's only temporary, and doesn't accomplish what's described in Messages 4 & 9.
Kent Cooper, AIA
Message 17 of 34
ronjonp
Sorry .. did not read this entire thread.
Message 18 of 34
CADaSchtroumpf
I'm using the old method (since R12 at least) which is persistent when saving the file.
E_off to inactivate the entity(ies)
E_on to reactivate them as desired.
File: E_off-E_on.lsp
(defun c:e_off ( / js_off n ent dxf_ent )
  (princ "\nChoix des entités à inactiver: ")
  (setq js_off (ssget) n 0)
  (cond
    (js_off
      (repeat (sslength js_off)
        (setq
          ent (ssname js_off n)
          dxf_ent (entget ent)
        (if (not (member '(60 . 0) dxf_ent))
          (entmod (append dxf_ent '((60 . 1))))
          (entmod (subst '(60 . 1) '(60 . 0) dxf_ent))
        (setq n (1+ n))
    (T
      (princ "\nSélection vide.")
  (princ)
(defun c:e_on ( / js_off n js_swap n_swap ent ent_dxf js_on nb)
  (setq js_off (ssget "_X" '((60 . 1))) n 0)
  (cond
    (js_off
      (setq js_swap (ssget "_X"  '((-4 . "<NOT") (60 . 1) (-4 . "NOT>"))) n_swap 0)
      (cond
        (js_swap
          (repeat (sslength js_swap)
            (setq ent (ssname js_swap n_swap))
            (redraw ent 2)
            (setq n_swap (1+ n_swap))
        (setq ent (ssname js_off n))
        (setq dxf_ent (entget ent))
        (entmod (subst '(60 . 0) '(60 . 1) dxf_ent))
        (entupd ent)
        (setq n (1+ n))
      (princ "\nChoix des entités à réactiver: ")
      (setq js_on (ssget) n 0)
      (cond
        (js_on
          (repeat (sslength js_on)
            (if (ssmemb (ssname js_on n) js_off)
              (setq js_off (ssdel (ssname js_on n) js_off))
            (setq n (1+ n))
          (cond
            (js_off
              (setq nb 0)
                (setq ent (ssname js_off nb))
                (entupd ent)
                (setq nb (1+ nb))
              (cond
                (js_swap
                  (setq n_swap 0)
                    (redraw ent 1)
            (T
              (princ "\nAucune entité à réactivée!")
        (T
    (T
  (princ)
I created two buttons with the following instructions:
^C^C(if (not c:e_off) (load "E_off-E_on.lsp")) e_off
^C^C^C^C(if (not c:e_on) (load "E_off-E_on.lsp")) e_on
Message 19 of 34
john.uhden
@CADaSchtroumpf
Are you sure R12 provided a visibility property (dxf 60)?
John F. Uhden
Message 20 of 34
CADaSchtroumpf
Even R10 !
he specific assignment of group codes depends upon the item being
described in the file.  However, the type of the value this group supplies
is derived from the group code in the following way:
                    Group code range   Following value
                          0 - 9       String
                         10 - 59      Floating-point
                         60 - 79      Integer
                        210 - 239     Floating-point
                           999        Comment (string)
See dxf10
