formule in autocad
formule in autocad
peter__smith
formule in autocad
peter__smith
I have made in menu "drawing property", 2 field names: “test 1” and “test2”.  and I want to add a formule. If “test 1” is filled with text / not empty, then “test2” will show the letter “ok”.
Question:
Does someone know, how I can do that?
Kind regards,
Peter smith
vladimir_michl
There is no direct way to do that in AutoCAD. You will need an additional tool (e.g. a LISP routine) to auto-update the "test2" property - loaded on all workstations where the "test1" property may be changed.
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
Moshe-A
@peter__smith hi,
let's make things clear first
"drawing property" is a block with 2 attributes (fields) test1, test2 ?
why 2 fields is needed...if test1 is not empty, it is clear OK. if test1 is empty, it is clear wrong.
sounds logic?
Moshe
Rick_Tolleshaug_TSC
Here are two programming methods...
;; METHOD 1 - Using DOSLib (Robert McNeel)
;; setting field value to "" deletes entire field therefore " " (space) is used to clear "Test2"
(defun dwgpropf ()
  (dos_custominfo "Test2" (if (= (dos_custominfo "Test1") "") " " "ok"))
;; METHOD 2 - Using ActiveX
(defun dwgpropf (/ si v1)
  (setq si
    (vla-get-SummaryInfo
      (vla-get-ActiveDocument
        (vlax-get-acad-object))))
  (vla-GetCustomByKey si "Test1" 'v1)
  (vla-SetCustomByKey si "Test2" (if (= v1 "") "" "ok"))
