FOREACH
FOREACH
vishshreevT578L
Message 1 of 13
FOREACH
vishshreevT578L
(DEFUN C:EXTRPOINTS ()
(SETQ POLYENT (ENTGET (CAR (ENTSEL "\nSelect a polyline: "))))
CAN I MAKE A LIST OF ALL THE COORDINATES OF A POLYLINE USING "FOREACH" HERE, IF I CAN ....HOW?
Shreev
Replies (12)
Message 2 of 13
Kent1Cooper
If you mean the vertices, you could, but if it's a lightweight Polyline, it's perhaps easier to do it by leaving out all entity data entries that don't start with a 10 [the vertices]:
(setq VertexList
  (mapcar 'cdr ; take the 10's off the beginning of each
    (vl-remove-if-not
      '(lambda (x) (= (car x) 10)); a vertex entry
      POLYENT
    ); vl-remove...
  ); mapcar
); setq
[If you really mean just the raw coordinates, not differentiated into point lists, check out the 'Coordinates VLA Property, which you can get from either a lightweight or a heavy Polyline.]
But yes, there is a way to do it with (foreach):
(foreach entry POLYENT
  (if (= (car entry) 10); it's a vertex entry
    (setq VertexList (cons (cdr entry) VertexList)); then -- add point list [without the 10] to collective list
  ); if
); foreach
Use (reverse) on the result if you need them in the Polyline's drawn order, or use (reverse) on POLYENT at the beginning so it will build the list the other way.
Kent Cooper, AIA
Message 3 of 13
vishshreevT578L
I WANTED TO THIS USING FOREACH FUNCTION BUT NOW I CAME TO KNOW I CANNOT..
THANKS SIR
Shreev
Message 4 of 13
devitg
Why you can not ??
Message 5 of 13
vishshreevT578L
Can you give an example
Shreev
Message 6 of 13
devitg
See  solution by Kent Cooper
(setq polyent (entget(car(entsel ¨select the poly¨))))
(setq VertexList ())
); if
); foreach
(setq VertexList (reverse VertexList))
 it return
((-5323.34 21.1449) (-3529.54 2470.28) (-1255.43 2440.89) (2636.05 1902.08) (3371.21 -801.765) (3135.96 -2643.52) (-10.5496 -1898.98))
Message 7 of 13
devitg
Other sample using Foreach
(DEFUN MASSOC  (KEY ENTDATA / X NLIST)
  (FOREACH X  ENTDATA
    (IF (EQ KEY (CAR X))
      (SETQ NLIST (CONS (CDR X) NLIST))
      ) ;_ end of if
    ) ;_ end of foreach
  (REVERSE NLIST)
Whre key , shall be 10 , and entdata   (entget )enty))
Grab the books, they dont bite .
Message 8 of 13
john.uhden
Massoc is by Tony Tanzillo c. 1999.
I wonder which is faster, (vl-remove-if-not) or (massoc).
John F. Uhden
Message 9 of 13
devitg
Unknow author
(DEFUN MASSOC-VL (CODE ENTDATA) (MAPCAR 'CDR (VL-REMOVE-IF-NOT '(LAMBDA (X) (= CODE (CAR X))) ENTDATA)) )
Massoc-vl ,Is twice fast than  masso for a 336019  vertex lwpolyline ,
;;Massoc is by Tony Tanzillo c. 1999
  (FOREACH X  ENTDATA
      ) ;_ end of if
    ) ;_ end of foreach
  (REVERSE NLIST)
For 5 repeat
0.905 for massoc
0.453 for massoc-vl
Find attached the DWG and the lisp
Message 10 of 13
john.uhden
How about for 100,000 simpler polylines?
Could you also post your time test function?
John F. Uhden
Message 11 of 13
devitg
Unzip the attached , or
  (FOREACH X  ENTDATA
      ) ;_ end of if
    ) ;_ end of foreach
  (REVERSE NLIST)
;;;(massoc-vl 5 elst) NOT KNOW THE AUTHOR , BUT IT IS NOT MINE
(DEFUN MIL-INI  ()
  (SETQ INI@ (GETVAR "millisecs"))
(DEFUN MIL-FIN  ()
  (SETQ FIN@ (GETVAR "millisecs"))
  (SETQ MIL-IN-FIN (/ (- FIN@ INI@) 1000.0))
(setq ent-data(entget (car(entsel))))
(setq data-qty (LENGTH ent-data))
(defun c:mas ()
(setq n-list ())
(setq   cmdecho (getvar 'cmdecho))
(setvar 'cmdecho 0)
(MIL-INI)
(repeat 5
  (massoc 10 ent-data)
(mil-fin)
(setvar 'userr1 MIL-IN-FIN)
(defun c:mas-vl ()
(setq n-list ())
(setvar 'cmdecho 0)
(MIL-INI)
(repeat 5
  (MASSOC-VL 10 ent-data)
(mil-fin)
(setvar 'userr2 MIL-IN-FIN)
(getvar 'userr1 )
(getvar 'userr2 )
Message 12 of 13
john.uhden
Bummer. 2002 doesn't have "mllisecs."
John F. Uhden
Message 13 of 13
john.uhden
Here's a timer function I dug out of my stuff from 2001:
(defun timer (fun n / start stop)
  (setq start (getvar "date"))
  (repeat n (eval fun))
  (setq stop (getvar "date"))
  (princ (strcat "Elapsed time for " (itoa n) " iterations: " (rtos (* 86400.0 (- stop start)) 2 2) " secs.\n"))
  (eval fun)
So I tried it on 1 14± vertex LWPOLYLINE...
Command: (setq ent (entget (car (entsel))))
Select object: ((-1 . <Entity name: 40082d88>) (0 . "LWPOLYLINE") (330 .
<Entity name: 40082cf8>) (5 . "31") (100 . "AcDbEntity") (67 . 0) (410 .
"Model") (8 . "0") (100 . "AcDbPolyline") (90 . 14) (70 . 128) (43 . 0.0) (38 .
0.0) (39 . 0.0) (10 4.97271 1.65594) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10
5.3741 2.68069) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 6.05794 2.63614) (40 .
0.0) (41 . 0.0) (42 . 0.0) (10 6.3404 2.88861) (40 . 0.0) (41 . 0.0) (42 . 0.0)
(10 6.80124 2.23515) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 7.36616 2.72525) (40
. 0.0) (41 . 0.0) (42 . 0.0) (10 7.75268 1.80446) (40 . 0.0) (41 . 0.0) (42 .
0.0) (10 8.24326 2.11634) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 8.78546 1.26347)
(40 . 0.0) (41 . 0.0) (42 . 0.0) (10 9.145 1.49204) (40 . 0.0) (41 . 0.0) (42 .
0.0) (10 9.50688 1.18069) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 10.1164 1.35891)
(40 . 0.0) (41 . 0.0) (42 . 0.0) (10 10.3988 1.09158) (40 . 0.0) (41 . 0.0) (42
. 0.0) (10 10.9786 1.2698) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0))
Command: (timer '(massoc 10 ent) 100000)
Elapsed time for 100000 iterations: 12.97 secs.
Command: (timer '(massoc-vl 10 ent) 100000)
Elapsed time for 100000 iterations: 16.62 secs.
Don't consider the time values as absolute.  I am running ACAD 2002 vanilla on a 2010 Dell I-7 laptop with many problems, the worst of which is that it just turns itself off every 15 minutes or so, I think depending on the level of graphic activity.  Any clues?
John F. Uhden
