So i have the code below and without flatten it is not working 100% correctly please view dwg and pic for what i mean. The line highlighted is suppose to be broken up into several pieces and any duplicate lines should be removed.
(acet-autoload2 '("FLATTENSUP.LSP" (acet-flatn ss hide)))
(defun ZZZ ()
(prompt "Zoom to LIMMIN / LIMMAX. ")
(setvar "CMDECHO" 0)
(vl-cmdf ".UCS" "World")
(vl-cmdf ".ZOOM" (getvar "LIMMIN") (getvar "LIMMAX"))
(vl-cmdf ".UCS" "Previous")
(setvar "CMDECHO" 1)
(princ)
);end ZZZ
(defun c:CleanUp2 (/ GetLines GetText GetArrows)
(ZZZ)
(setq GetLines (ssget "_A" '((0 . "LINE"))))
(vl-cmdf "._erase" GetLines "")
(setq GetText (ssget "_A" '((0 . "TEXT"))))
(vl-cmdf "._erase" GetText "")
(setq GetArrows (ssget "x" (list (cons 0 "lwpolyline") (cons 70 0))))
(vl-cmdf "._erase" GetArrows "")
(princ)
(ocz)
(defun ocz (/ xAxis1 xAxis2 xAxis3 xAxis4 yAxis1 yAxis2 yAxis3 yAxis4)
(setq sset (ssget "x" (list (cons 0 "lwpolyline") (cons 70 1))))
(if sset
(progn
(setq itm 0
num (sslength sset)
; (if (itm /= 1)
(while (< itm num)
(setq hnd (ssname sset itm))
(setq ent (entget hnd))
(setq obj (cdr (assoc 0 ent)))
(cond
((= obj "LWPOLYLINE")
(if (= (cdr (assoc 38 ent)) nil)
(setq elv 0.0)
(setq elv (cdr (assoc 38 ent)))
(foreach rec ent
(if (= (car rec) 10)
(progn
(setq pnt (cdr rec))
(setq pnt (trans pnt 0 1))
;;**CAB
(cond ((null xAxis1)
(setq xAxis1 (strcat (rtos (car pnt) 2 3)))
(setq yAxis1 (strcat (rtos (cadr pnt) 2 3)))
((null xAxis2)
(setq xAxis2 (strcat (rtos (car pnt) 2 3)))
(setq yAxis2 (strcat (rtos (cadr pnt) 2 3)))
((null xAxis3)
(setq xAxis3 (strcat (rtos (car pnt) 2 3)))
(setq yAxis3 (strcat (rtos (cadr pnt) 2 3)))
((null xAxis4)
(setq xAxis4 (strcat (rtos (car pnt) 2 3)))
(setq yAxis4 (strcat (rtos (cadr pnt) 2 3)))
(if (= xAxis1 xAxis2)
(progn
(setq p1 (strcat xAxis1 "," yAxis1))
(setq p2 (strcat xAxis2 "," yAxis2))
(command "line" p1 p2 "")
(if (= xAxis1 xAxis3)
(progn
(setq p3 (strcat xAxis1 "," yAxis1))
(setq p4 (strcat xAxis3 "," yAxis3))
(command "line" p3 p4 "")
(if (= xAxis1 xAxis4)
(progn
(setq p5 (strcat xAxis1 "," yAxis1))
(setq p6 (strcat xAxis4 "," yAxis4))
(command "line" p5 p6 "")
(if (= xAxis3 xAxis2)
(progn
(setq p7 (strcat xAxis3 "," yAxis3))
(setq p8 (strcat xAxis2 "," yAxis2))
(command "line" p7 p8 "")
(if (= xAxis4 xAxis2)
(progn
(setq p9 (strcat xAxis4 "," yAxis4))
(setq p10 (strcat xAxis2 "," yAxis2))
(command "line" p9 p10 "")
(if (= xAxis3 xAxis4)
(progn
(setq p11 (strcat xAxis3 "," yAxis3))
(setq p12 (strcat xAxis4 "," yAxis4))
(command "line" p11 p12 "")
(if (= yAxis1 yAxis2)
(progn
(if (= yAxis1 yAxis3)
(progn
(if (= yAxis1 yAxis4)
(progn
(if (= yAxis3 yAxis2)
(progn
(if (= yAxis4 yAxis2)
(progn
(if (= yAxis3 yAxis4)
(progn
(setq xAxis1 nil)
(setq xAxis2 nil)
(setq xAxis3 nil)
(setq xAxis4 nil)
(t nil)
(setq itm (1+ itm))
(vl-cmdf "._erase" sset "")
(princ)
(FLATTEN)
(defun Flatten (/ ss ans)
(acet-error-init (list nil 1))
(if (not acet:flatn-hide)
(setq acet:flatn-hide "No")
) ;if
(if (and (setq ss (ssget "_A" '((0 . "LINE")))) ;setq
(setq ss (car (acet-ss-filter (list ss nil T))))
) ;and
(progn
(setq ans "yes"
) ;setq
(out if (not ans)
(setq ans acet:flatn-hide)
(setq acet:flatn-hide ans)
) ;if
(if (equal ans "No")
(acet-flatn ss nil)
(acet-flatn ss T)
) ;if
) ;progn then
) ;if
(acet-error-restore)
(princ)
(command "_.-OVERKILL" "_all" "" "Done")
(princ)
(BreakAll)
(if (zerop (getvar "PEDITACCEPT"))
(command "._PEDIT" "_M" (ssget "_A" '((0 . "*POLYLINE,LINE"))) "" "_Y" "")
(command "._PEDIT" "_M" (ssget "_A" '((0 . "*POLYLINE,LINE"))) "" "")
;(CreatePath2)
) ;defun c:flatten
(defun CreatePath2 (/ xAxis1
xAxis2 yAxis1 yAxis2 xAxis3
xAxis3 xAxis4 yAxis4 CurrentX
CurrentY PossibleLines MainLine AllLines DidLines CurrentEnt pt ss in sn cl ls sn HasRight HasLeft Leftx Lefty Rightx Righty
(setq *des* (open (strcat "C:\\Users\\RPajo\\OneDrive\\Desktop\\Customs\\ISO\\" (getvar "dwgname") ".ISO") "w"))
;(setq *des* (open (strcat "C:\\Users\\RPajo\\OneDrive\\Desktop\\Customs\\ISO\\Test.ISO") "w"))
(setq CurrentX "0")
(setq CurrentY "0")
(setq First 1)
(write-line (strcat "G90 G92 X" CurrentX " Y" CurrentY) *des*)
(setq sset (ssget "_A" '((0 . "*POLYLINE,LINE"))))
(setq PossibleLines (ssadd))
(setq AllLines (ssadd))
(setq DidLines 0)
(if sset
(progn
(setq itm3 0
num3 (sslength sset))
(while (< itm3 num3)
(setq hnd3 (ssname sset itm3))
(ssadd hnd3 AllLines)
(setq itm3 (1+ itm3))
( while (and (/= (sslength AllLines) 0) (/= DidLines 99))
(if sset
(progn
(if (and (/= DidLines 0) (= (rem DidLines 4) 0))
(progn
(write-line "M00" *des*)
(write-line (strcat "G00 X" CurrentX " Y" CurrentY) *des*)
(setq itm 0
num (sslength sset))
(while (< itm num)
(setq Allowed (IsInList hnd AllLines))
(foreach rec ent
(progn
((null xAxis2)
(cond
((and (= CurrentX xAxis1) (= CurrentY yAxis1) (= Allowed 1))
(ssadd hnd PossibleLines)
((and (= CurrentX xAxis2) (= CurrentY yAxis2) (= Allowed 1))
(setq xAxis1 nil)
(setq xAxis2 nil)
(setq itm (1+ itm))
(if (and (= First 1) (= (sslength PossibleLines) 0))
(progn
(setq First 0)
(setq pnt (list (read Currentx) (read CurrentY) 0.0))
(sssetfirst nil nil)
(setq distanceFromPoint nil)
(setq nearestPointTo nil)
(setq ent nil)
(repeat (setq i (sslength AllLines))
(setq ent (ssname AllLines (setq i (1- i))))
(cons (list (distance pnt
(setq nearestPointTo (vlax-curve-getClosestPointTo ent pnt)))
ent nearestPointTo) distanceFromPoint ))
(setq theNearest (Car (vl-sort distanceFromPoint '(lambda (a b)(< (Car a)(car b))))))
(setq EntName (cadr theNearest))
(sssetfirst nil (ssadd EntName))
(setq ent2 (entget EntName))
(foreach rec2 ent2
(if (= (car rec2) 10)
(progn
(setq pnt2 (cdr rec2))
(setq pnt2 (trans pnt2 0 1))
(cond ((null xAxis3)
(setq xAxis3 (strcat (rtos (car pnt2) 2 3)))
(setq yAxis3 (strcat (rtos (cadr pnt2) 2 3)))
((null xAxis4)
(setq xAxis4 (strcat (rtos (car pnt2) 2 3)))
(setq yAxis4 (strcat (rtos (cadr pnt2) 2 3)))
(setq pnt3 (list (read xAxis3) (read yAxis3) 0.0))
(if (> (distance pnt2 pnt ) (distance pnt3 pnt))
(progn
(setq CurrentX xAxis3)
(setq CurrentY yAxis3)
(write-line (strcat "G01 X" xAxis3 " Y" yAxis3) *des*)
(progn
(setq CurrentX xAxis4)
(setq CurrentY yAxis4)
(write-line (strcat "G01 X" xAxis4 " Y" yAxis4) *des*)
(setq xAxis3 nil)
(setq xAxis4 nil)
(progn
(setq First 0)
(setq MainLine "Not Found")
(setq DidSomething 0)
(setq HasRight 0)
(setq HasLeft 0)
(if (/= (sslength PossibleLines) 0)
(progn
(setq itm2 0
num2 (sslength PossibleLines)
(while (and (< itm2 num2) (/= MainLine "Found"))
(setq hnd2 (ssname PossibleLines itm2))
(setq ent2 (entget hnd2))
(setq obj2 (cdr (assoc 0 ent2)))
(foreach rec2 ent2
(progn
((null xAxis4)
(setq pnt (list (read CurrentX) (read CurrentY) 0.0))
(if (and (= CurrentX xAxis3) (= CurrentX xAxis4) (= DidSomething 0))
(progn
(if (and (< (atoi yAxis3) (atoi CurrentY)) (/= yAxis3 CurrentY) (/= pnt pnt3))
(progn
(ssdel hnd2 AllLines)
(print (strcat "Going From (" Currentx ", " Currenty ") to (" xAxis3 ", " yAxis3 ")"))
(command "chprop" hnd2 "" "C" 3 "")
(setq DidSomething 1)
(setq MainLine "Found")
(if (and (< (atoi yAxis4) (atoi CurrentY)) (/= yAxis4 CurrentY) (/= pnt pnt2))
(progn
(print (strcat "Going From (" Currentx ", " Currenty ") to (" xAxis4 ", " yAxis4 ")"))
(if (and (= Currenty yAxis3) (= Currenty yAxis4) (= DidSomething 0))
(progn
(if (/= Currentx xAxis3 )
(progn
(if (> Currentx xAxis3)
(progn
(setq HasLeft hnd2)
(setq Leftx xAxis3)
(setq Lefty yAxis3)
(progn
(setq HasRight hnd2)
(setq Rightx xAxis3)
(setq Righty yAxis3)
(if (/= Currentx xAxis4 )
(progn
(if (> Currentx xAxis4)
(progn
(setq HasLeft hnd2)
(setq Leftx xAxis4)
(setq Lefty yAxis4)
(progn
(setq Rightx xAxis4)
(setq Righty yAxis4)
(if (and (= num2 1) (= DidSomething 0))
(progn
(if (or (/= Currentx xAxis3 ) (/= Currenty yAxis3))
(progn
(if (or (and (/= Currentx xAxis4 ) (= DidSomething 0)) (and (/= Currenty yAxis4) (= DidSomething 0)))
(progn
(if (and (= (1- num2) itm2) (= DidSomething 0))
(progn
(if (/= HasRight 0)
(progn
(ssdel HasRight AllLines)
(print (strcat "Going From (" Currentx ", " Currenty ") to (" Rightx ", " Righty ")"))
(write-line (strcat "G01 X" Rightx " Y" Righty) *des*)
(command "chprop" HasRight "" "C" 3 "")
(setq CurrentX Rightx)
(setq CurrentY Righty)
(progn
(if (/= HasLeft 0)
(progn
(ssdel HasLeft AllLines)
(print (strcat "Going From (" Currentx ", " Currenty ") to (" Leftx ", " Lefty ")"))
(write-line (strcat "G01 X" Leftx " Y" Lefty) *des*)
(command "chprop" HasLeft "" "C" 3 "")
(setq CurrentX Leftx)
(setq CurrentY Lefty)
(progn
(progn
(princ (strcat "Going From (" Currentx ", " Currenty ") to (" xAxis3 ", " yAxis3 ")"))
(progn
(princ (strcat "Going From (" Currentx ", " Currenty ") to (" xAxis4 ", " yAxis4 ")"))
(setq xAxis3 nil)
(setq xAxis4 nil)
(setq itm2 (1+ itm2))
( progn
(setq ent nil)
(foreach rec2 ent2
(progn
((null xAxis4)
(progn
;(ssdel EntName AllLines)
;(print (strcat "Going From9 (" Currentx ", " Currenty ") to (" xAxis3 ", " yAxis3 ")"))
;(command "chprop" EntName "" "C" 3 "")
;(setq DidSomething 1)
(shortlinespath pnt pnt3)
(progn
;(print (strcat "Going From10 (" Currentx ", " Currenty ") to (" xAxis4 ", " yAxis4 ")"))
(shortlinespath pnt pnt2)
(setq xAxis3 nil)
(setq xAxis4 nil)
(setq DidLines (1+ DidLines))
(write-line "M30" *des*)
(close *des*)
(princ "Done")
(defun IsInList( Enitity ListToCheck)
(setq DidFind 0)
(if ListToCheck
(progn
(setq itm4 0
num4 (sslength ListToCheck))
(while (< itm4 num4)
(setq hnd4 (ssname ListToCheck itm4))
(if (equal Enitity hnd4)
(progn
(print)
(setq DidFind 1)
(setq itm4 (1+ itm4))
(eval DidFind)
; Find the path of minimum total length between two given nodes g and f. ;
; Using Dijkstra Algorithm ;
; See http://tech-algorithm.com/articles/dijkstra-algorithm/ ;
; Written by ymg August 2013 ;
(defun minpath ( g f nodes edges / brname clnodes closedl dst1 dst2 m minpath minpathn mp new nodname old oldpos openl totdist )
(setq nodes (vl-remove g nodes)
openl (list (list g 0 nil))
closedl nil
(foreach n nodes
(setq nodes (subst (list n 0 nil) n nodes))
(while (not (equal (caar closedl) f 1))
(setq nodname (caar openl)
totdist (cadar openl)
closedl (cons (car openl) closedl)
openl (cdr openl)
clnodes (mapcar 'car closedl)
(foreach e edges
(setq brname nil)
(if (equal (car e) nodname 1)
(setq brname (cadr e))
(if (equal (cadr e) nodname 1)
(setq brname (car e))
(if brname
(progn
(setq new (list brname (+ (caddr e) totdist) nodname))
(cond
((member brname clnodes))
((setq oldpos (vl-position brname (mapcar 'car openl)))
(setq old (nth oldpos openl))
(if (< (cadr new) (cadr old))
(setq openl (subst new old openl))
(t (setq openl (cons new openl)))
(setq edges (vl-remove e edges))
(setq
openl (vl-sort openl
(function (lambda (a b) (< (cadr a) (cadr b))))
(setq minpath (list (list (car closedl))))
(setq dst1 (cadr (car closedl)))
(setq m 1)
(foreach k closedl
(setq dst2 (cadr k))
(if (not (equal dst1 dst2 1)) (setq m (1+ m) dst1 dst2))
(repeat m
(foreach n closedl
(if (= (length minpath) 1)
(if (equal (car n) (caddr (caar minpath)) 1) (setq mp (cons n mp)))
(mapcar '(lambda (x) (if (equal (car n) (caddr (car x)) 1) (setq mp (cons n mp)))) minpath)
(setq mp (vl-sort mp '(lambda (a b) (not (equal (car b) (car a) 1)))))
(setq minpath (mapcar '(lambda (x) (cons x (car minpath))) mp))
(setq minpath (mapcar '(lambda (x) (mapcar '(lambda (y) (if (equal (car x) (caddr (car y)) 1) (cons x y))) minpath)) mp))
(setq minpath (mapcar '(lambda (x) (vl-remove nil x)) minpath))
(if (listp (caaaar minpath)) (setq minpath (apply 'append minpath)))
(mapcar '(lambda (x) (if (eq (caddr (car x)) nil) (setq minpathn (cons x minpathn)))) minpath)
(setq mp nil)
(setq minpathn (acet-list-remove-duplicates minpathn nil))
(setq minpathn (vl-remove nil minpathn))
(defun make3dpl ( ptlst )
(setq i 0)
(foreach pt ptlst
(if (/= i 0 )
(progn
(Print (strcat "going from (" (rtos (car pt) 2 3) ", " (rtos (cadr pt) 2 3) ", 0.0) ->" ))
(write-line (strcat "G01 X" (rtos (car pt) 2 3) " Y" (rtos (cadr pt) 2 3)) *des*)
(setq i (1+ i))
(defun shortlinespath ( g f / osm ss i lin p1 p2 linlst ptlst dijkstra ptlstpths pl )
(vl-load-com)
(setq osm (getvar 'osmode))
(setq ss (ssget "_A" '((0 . "*POLYLINE,LINE,CIRCLE"))))
(setq i -1)
(while (setq lin (ssname ss (setq i (1+ i))))
(setq p1 (vlax-curve-getStartPoint lin)
p2 (vlax-curve-getEndPoint lin)
(setq linlst (cons (list p1 p2 (distance p1 p2)) linlst))
(setq ptlst (cons p1 ptlst) ptlst (cons p2 ptlst))
(setq ptlst (acet-list-remove-duplicates ptlst 1))
(setvar 'osmode 1)
(setq dijkstra (minpath g f ptlst linlst))
(setq ptlstpths (mapcar '(lambda (x) (mapcar 'car x)) dijkstra))
(mapcar '(lambda (x) (make3dpl x)) ptlstpths)
(prompt "\nShortest path length is : ") (princ (rtos (setq len (cadr (last (car dijkstra)))))) (prompt " - you should check length to match data")
(setvar 'osmode osm)
(princ)
(defun BreakAll (/ cmd ss NewEnts AllEnts tmp)
(setq cmd (getvar "CMDECHO"))
(initget 4) ; no negative numbers
(setq Bgap 0)
;; get objects to break
(if (setq ss (ssget "_A" '((0 . "*POLYLINE,LINE,CIRCLE"))))
(setq NewEnts (Break_with ss ss nil Bgap) ; ss2break ss2breakwith (flag nil = not to break with self)
; AllEnts (append NewEnts (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(setvar "CMDECHO" cmd)
(princ)
(defun break_with (ss2brk ss2brkwith self Gap / cmd intpts lst masterlist ss ssobjs
onlockedlayer ssget->vla-list list->3pair GetNewEntities oc
get_interpts break_obj GetLastEnt LastEntInDatabase ss2brkwithList
;; ss2brk selection set to break
;; ss2brkwith selection set to use as break points
;; self when true will allow an object to break itself
;; note that plined will break at each vertex
;; return list of enames of new objects
(vl-load-com)
(princ "\nCalculating Break Points, Please Wait.\n")
;; S U B F U N C T I O N S
;; return T if entity is on a locked layer
(defun onlockedlayer (ename / entlst)
(setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
(= 4 (logand 4 (cdr (assoc 70 entlst))))
;; return a list of objects from a selection set
;| (defun ssget->vla-list (ss)
(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss ))))
(defun ssget->vla-list (ss / i ename allobj) ; this is faster, changed in ver 1.7
(setq i -1)
(while (setq ename (ssname ss (setq i (1+ i))))
(setq allobj (cons (vlax-ename->vla-object ename) allobj))
allobj
;; return a list of lists grouped by 3 from a flat list
(defun list->3pair (old / new)
(while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
old (cdddr old)))
(reverse new)
;; return a list of intersect points
(defun get_interpts (obj1 obj2 / iplist)
(if (not (vl-catch-all-error-p
(setq iplist (vl-catch-all-apply
'vlax-safearray->list
(list
(vlax-variant-value
(vla-intersectwith obj1 obj2 acextendnone)
iplist
;; Break entity at break points in list
;; New as per version 1.8 [BrkGap] --- This subroutine has been re-written
;; Loop through the break points breaking the entity
;; If the entity is not a closed entity then a new object is created
;; This object is added to a list. When break points don't fall on the current
;; entity the list of new entities are searched to locate the entity that the
;; point is on so it can be broken.
;; "Break with a Gap" has been added to this routine. The problem faced with
;; this method is that sections to be removed may lap if the break points are
;; too close to each other. The solution is to create a list of break point pairs
;; representing the gap to be removed and test to see if there i an overlap. If
;; there is then merge the break point pairs into one large gap. This way the
;; points will always fall on an object with one exception. If the gap is too near
;; the end of an object one break point will be off the end and therefore that
;; point will need to be replaced with the end point.
;; NOTE: in ACAD2000 the (vlax-curve-getdistatpoint function has proven unreliable
;; so I have used (vlax-curve-getdistatparam in most cases
(defun break_obj (ent brkptlst BrkGap / brkobjlst en enttype maxparam closedobj
minparam obj obj2break p1param p2param brkpt2 dlst idx brkptS
brkptE brkpt result GapFlg result ignore dist tmppt
#ofpts 2gap enddist lastent obj2break stdist
(or BrkGap (setq BrkGap 0.0)) ; default to 0
(setq BrkGap (/ BrkGap 2.0)) ; if Gap use 1/2 per side of break point
(setq obj2break ent
brkobjlst (list ent)
enttype (cdr (assoc 0 (entget ent)))
GapFlg (not (zerop BrkGap)) ; gap > 0
closedobj (vlax-curve-isclosed obj2break)
;; when zero gap no need to break at end points, not closed
(if (and (zerop Brkgap)(not closedobj)) ; Revision 2.2
(setq spt (vlax-curve-getstartpoint ent)
ept (vlax-curve-getendpoint ent)
brkptlst (vl-remove-if '(lambda(x) (or (< (distance x spt) 0.0001)
(< (distance x ept) 0.0001)))
brkptlst)
(if brkptlst
(progn
;; sort break points based on the distance along the break object
;; get distance to break point, catch error if pt is off end
;; ver 2.0 fix - added COND to fix break point is at the end of a
;; line which is not a valid break but does no harm
(setq brkptlst (mapcar '(lambda(x) (list x (vlax-curve-getdistatparam obj2break
;; ver 2.0 fix
(cond ((vlax-curve-getparamatpoint obj2break x))
(vlax-curve-getclosestpointto obj2break x))))))
) brkptlst))
;; sort primary list on distance
(setq brkptlst (vl-sort brkptlst '(lambda (a1 a2) (< (cadr a1) (cadr a2)))))
(if GapFlg ; gap > 0
;; Brkptlst starts as the break point and then a list of pairs of points
;; is creates as the break points
(progn
;; create a list of list of break points
;; ((idx# stpoint distance)(idx# endpoint distance)...)
(setq idx 0)
(foreach brkpt brkptlst
;; create start break point, then create end break point
;; ((idx# startpoint distance)(idx# endpoint distance)...)
(setq dist (cadr brkpt)) ; distance to center of gap
;; subtract gap to get start point of break gap
(cond
((and (minusp (setq stDist (- dist BrkGap))) closedobj )
(setq stdist (+ (vlax-curve-getdistatparam obj2break
(vlax-curve-getendparam obj2break)) stDist))
(setq dlst (cons (list idx
(vlax-curve-getpointatparam obj2break
(vlax-curve-getparamatdist obj2break stDist))
stDist) dlst))
((minusp stDist) ; off start of object so get startpoint
(setq dlst (cons (list idx (vlax-curve-getstartpoint obj2break) 0.0) dlst))
(t
stDist) dlst))
;; add gap to get end point of break gap
(cond
((and (> (setq stDist (+ dist BrkGap))
(setq endDist (vlax-curve-getdistatparam obj2break
(vlax-curve-getendparam obj2break)))) closedobj )
(setq stdist (- stDist endDist))
stDist) dlst))
((> stDist endDist) ; off end of object so get endpoint
endDist) dlst))
(t
stDist) dlst))
(setq idx (1+ IDX))
) ; foreach brkpt brkptlst
(setq dlst (reverse dlst))
;; remove the points of the gap segments that overlap
(setq idx -1
2gap (* BrkGap 2)
#ofPts (length Brkptlst)
(while (<= (setq idx (1+ idx)) #ofPts)
(cond
((null result) ; 1st time through
(setq result (list (car dlst)) ; get first start point
result (cons (nth (1+(* idx 2)) dlst) result))
((= idx #ofPts) ; last pass, check for wrap
(if (and closedobj (> #ofPts 1)
(<= (+(- (vlax-curve-getdistatparam obj2break
(cadr (last BrkPtLst))) (cadar BrkPtLst)) 2Gap))
(progn
(if (zerop (rem (length result) 2))
(setq result (cdr result)) ; remove the last end point
;; ignore previous endpoint and present start point
(setq result (cons (cadr (reverse result)) result) ; get last end point
result (cdr (reverse result))
result (reverse (cdr result)))
;; Break Gap Overlaps
((< (cadr (nth idx Brkptlst)) (+ (cadr (nth (1- idx) Brkptlst)) 2Gap))
(setq result (cons (nth (1+(* idx 2)) dlst) result)) ; get present end point
;; Break Gap does Not Overlap previous point
(t
(setq result (cons (nth (* idx 2) dlst) result)) ; get this start point
(setq result (cons (nth (1+(* idx 2)) dlst) result)) ; get this end point
) ; end cond stmt
) ; while
;; setup brkptlst with pair of break pts ((p1 p2)(p3 p4)...)
;; one of the pair of points will be on the object that
;; needs to be broken
(setq dlst (reverse result)
brkptlst nil)
(while dlst ; grab the points only
(setq brkptlst (cons (list (cadar dlst)(cadadr dlst)) brkptlst)
dlst (cddr dlst))
;; (if (equal a ent) (princ)) ; debug CAB -------------
(foreach brkpt (reverse brkptlst)
(setq brkptS (car brkpt)
brkptE (cadr brkpt))
brkptE brkptS)
;; get last entity created via break in case multiple breaks
(if brkobjlst
(progn
(setq tmppt brkptS) ; use only one of the pair of breakpoints
;; if pt not on object x, switch objects
(if (not (numberp (vl-catch-all-apply
'vlax-curve-getdistatpoint (list obj2break tmppt))))
(progn ; find the one that pt is on
(setq idx (length brkobjlst))
(while (and (not (minusp (setq idx (1- idx))))
(setq obj (nth idx brkobjlst))
(if (numberp (vl-catch-all-apply
'vlax-curve-getdistatpoint (list obj tmppt)))
(null (setq obj2break obj)) ; switch objects, null causes exit
t
;| ;; ver 2.0 fix - removed this code as there are cases where the break point
;; is at the end of a line which is not a valid break but does no harm
(if (and brkobjlst idx (minusp idx)
(null (alert (strcat "Error - point not on object"
"\nPlease report this error to"
"\n CAB at TheSwamp.org"))))
(exit)
;; (if (equal (if (null a)(setq a (car(entsel"\nTest Ent"))) a) ent) (princ)) ; debug CAB -------------
;; Handle any objects that can not be used with the Break Command
;; using one point, gap of 0.000001 is used
(setq closedobj (vlax-curve-isclosed obj2break))
(if closedobj
(progn ; need to break a closed object
(setq brkpt2 (vlax-curve-getPointAtDist obj2break
(- (vlax-curve-getDistAtPoint obj2break brkptE) 0.00001)))
(command "._break" obj2break "_non" (trans brkpt2 0 1)
"_non" (trans brkptE 0 1))
(and (= "CIRCLE" enttype) (setq enttype "ARC"))
(setq BrkptE brkpt2)
;; single breakpoint ----------------------------------------------------
;|(if (and closedobj ; problems with ACAD200 & this code
(not (setq brkptE (vlax-curve-getPointAtDist obj2break
(+ (vlax-curve-getDistAtPoint obj2break brkptS) 0.00001))))
(- (vlax-curve-getDistAtPoint obj2break brkptS) 0.00001)))
(if (and closedobj
;;(vlax-curve-getparamatpoint obj2break brkpts)) 0.00001))))
;; ver 2.0 fix
(cond ((vlax-curve-getparamatpoint obj2break brkpts))
(vlax-curve-getclosestpointto obj2break brkpts))))) 0.00001)))))
;; ver 2.0 fix
) ; endif
;; (if (null brkptE) (princ)) ; debug
(setq LastEnt (GetLastEnt))
(command "._break" obj2break "_non" (trans brkptS 0 1) "_non" (trans brkptE 0 1))
(and *BrkVerbose* (princ (setq *brkcnt* (1+ *brkcnt*))) (princ "\r"))
(if (and (not closedobj) ; new object was created
(not (equal LastEnt (entlast))))
(setq brkobjlst (cons (entlast) brkobjlst))
) ; endif brkptlst
) ; defun break_obj
;; CAB - get last entity in datatbase
(defun GetLastEnt ( / ename result )
(if (setq result (entlast))
(while (setq ename (entnext result))
(setq result ename)
result
;; CAB - return a list of new enames
(defun GetNewEntities (ename / new)
(cond
((null ename) (alert "Ename nil"))
((eq 'ENAME (type ename))
(while (setq ename (entnext ename))
(if (entget ename) (setq new (cons ename new)))
((alert "Ename wrong type."))
new
;; S T A R T S U B R O U T I N E H E R E
(setq LastEntInDatabase (GetLastEnt))
(if (and ss2brk ss2brkwith)
(progn
(setq oc 0
ss2brkwithList (ssget->vla-list ss2brkwith))
(if (> (* (sslength ss2brk)(length ss2brkwithList)) 5000)
(setq *BrkVerbose* t)
(and *BrkVerbose*
(princ (strcat "Objects to be Checked: "
(itoa (* (sslength ss2brk)(length ss2brkwithList))) "\n")))
;; CREATE a list of entity & it's break points
(foreach obj (ssget->vla-list ss2brk) ; check each object in ss2brk
(if (not (onlockedlayer (vlax-vla-object->ename obj)))
(progn
(setq lst nil)
;; check for break pts with other objects in ss2brkwith
(foreach intobj ss2brkwithList
(if (and (or self (not (equal obj intobj)))
(setq intpts (get_interpts obj intobj))
(setq lst (append (list->3pair intpts) lst)) ; entity w/ break points
(and *BrkVerbose* (princ (strcat "Objects Checked: " (itoa (setq oc (1+ oc))) "\r")))
(if lst
(setq masterlist (cons (cons (vlax-vla-object->ename obj) lst) masterlist))
(and *BrkVerbose* (princ "\nBreaking Objects.\n"))
(setq *brkcnt* 0) ; break counter
;; masterlist = ((ent brkpts)(ent brkpts)...)
(if masterlist
(foreach obj2brk masterlist
(break_obj (car obj2brk) (cdr obj2brk) Gap)
(and (zerop *brkcnt*) (princ "\nNone to be broken."))
(setq *BrkVerbose* nil)
(GetNewEntities LastEntInDatabase) ; return list of enames of new objects
