Fix lisp
Fix lisp
Automohan
Fix lisp
Automohan
Lisp error...
(defun c:zw (/ pt1 pt2)
(if
  (and
   (setq pt1 (getpoint "\nSelect First Window Point: "))
   (setq pt1 (osnap pt1 "_end"))
   (setq pt2 (getpoint "\nSelect Second Window Point: "))
   (setq pt2 (osnap pt2 "_end"))
   (command "._zoom" "_w" "_non" pt1 "_non" pt2) ; end zoom
   (command "_.pspace")
   (command "_.MVIEW" "L" "ON" "P" "")
(princ)
) ; end of program
"Save Energy"
Did you find this reply helpful? If so please use the Accept as Solution
cadffm
IF expect just one exoression for THEN case.
Use PROGN or use just one (command ..) function.
[F1] if (AutoLISP)
Sebastian
Automohan
(if
  (and
   (command "._zoom" "_w" "_non" pt1 "_non" pt2 "_.pspace" "_.mview" "l" "on" "l" "")
(princ)
); end of program
"Save Energy"
