FIX LINES TO SNAP POINTS...
marko_ribar
Advisor Advisor
marko_ribar
As it's stated in title, I want to set SNAPUNIT system variable... Values can differ in X and Y directions...
Then routine will ask to select LINES and then they will be modified so that each end point coincide with SNAP points when SNAP is turned ON...
I haven't started anything as I don't know how to approach to this task, so your input would be appreciated with welcome...
M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
marko_ribar
I double posted this problem, so just to inform here is the link to the topic you should check too :
http://www.theswamp.org/index.php?topic=56389.0
marko_ribar
If the end point of 2D LINE is somewhere in between all 4 surrounding SNAP POINTS - here is the priority order (left->right;bottom->up)... So this order : lower left SNAP POINT, upper left SNAP POINT, lower right SNAP POINT, upper right SNAP POINT...
marko_ribar
I've found a solution with help of Stefan... My kudos to him...
http://www.theswamp.org/index.php?topic=56389.msg602376#msg602376
CodeDing
@marko_ribar ,
You don't need to create any custom functions for this. There's actually an AutoLISP funciton built-in to handle this.
It's the (osnap ...) function. That looks like what you're asking for (see the link).
Best,
~DD
CodeDing
@marko_ribar ,
It was brought to my attention that this is referring to Grid snap, NOT Object snap. I misunderstood.
Best,
~DD
vladimir_michl
There is a good old utility - FixOffGrid - for this (by Joe Burke).
Vladimir Michl, www.cadstudio.cz - www.cadforum.cz
