We use a lisp to create an arc tangent to 3 lines and it is not working in 2017
I have gone through the lisp and from what I understand it does the following:
(defun c:fa ( / pt1 pt2 pt3 cen ent1 ent2 ent3 pt4)
;define functions
(setq oldosmode (getvar "OSMODE"))
;save current osmode
(setvar "OSMODE" (+ 1024 512))
;set osnap to geometric center and nearest
(setq oldhighlight (getvar "HIGHLIGHT"))
;save current highlight mode
(setvar "HIGHLIGHT" 0)
;turn off highlight
(initget 1)
;prevents the user from responding to the request by entering only Enter
(setq pt1 (getpoint "\nPoint to first line: "))
;prompts user to select a point on the first line and defines that point as pt1
(initget 1)
(setq pt2 (getpoint "\nPoint to second line: "))
;prompts user to select a point on the second line and defines that point as pt2
(initget 1)
(setq pt3 (getpoint "\nPoint to third line: "))
;prompts user to select a point on the third line and defines that point as pt3
(setvar "OSMODE" (+ 1024 256))
;set osnap to geometric center and tangent
(command "circle" "3p" pt1 pt2 pt3)
;draws circle 3 point with tangent osnap to pt1 pt2 and pt3
(setvar "OSMODE" 0)
;turns osnaps off
(setq cen (trans (cdr (assoc 10 (entget (entlast)))) 0 1))
;sets cen to the center of the circle just drawn
(entdel (entlast))
;deletes the circle
(setvar "LASTPOINT" cen)
;sets lastpoint vsystem variable to cen (center of circle drawn and deleted)
;Everything seems to work up to here
(setq
pt1 (osnap pt1 "qui,per")
pt2 (osnap pt2 "qui,per")
pt3 (osnap pt3 "qui,per")
;I think this is supposed to redefine pt1, pt2, and pt3 to points on the lines perpendicular to the center of the circle but i don't think it is working
(setq
ent1 (ssget pt1)
ent2 (ssget pt2)
ent3 (ssget pt3)
pt4 (polar pt2 (angle cen pt2) (* 2.0 (distance cen pt2)))
;this is supposed to define ent1, ent2, and ent3 by selecting the object that passes through pt1, pt2, and pt3 respectively, and then defines pt4 as a point twice the radius of the circle and polar to the angle from the center of the circle to point 2
(command "break" ent1 pt1 pt4)
;breaks ent1 at pt1 to pt4
(command "break" ent3 pt3 pt4)
;breaks ent2 at pt1 to pt4
(command "erase" ent2 "")
;erases ent2
(command "arc" pt1 pt2 pt3)
;draws an arc from pt1 through pt2 to pt3
(setvar "HIGHLIGHT" oldhighlight)
;returns highlight to original setting
(setq oldhighlight nil)
;removes oldhighlight value
(setvar "osmode" oldosmode)
;sets osnaps to previous setting
(setq oldosmode nil)
;removes oldosmode value
(princ)
The lisp routine is below. Can anyone tell me why this isn't working?
;given three lines, arcs or combination thereof, fits an arc tangent
;to all 3 and trims off excess.
(initget 1)
(initget 1)
(initget 1)
(setvar "OSMODE" 0)
(entdel (entlast))
(setq
(setq
ent1 (ssget pt1)
ent2 (ssget pt2)
ent3 (ssget pt3)
(princ)
