Finding lines that are not straight.
keshishian
Message 1 of 27
keshishian
Attached is a lisp command that moves all "non straight" lines to a new layer. It is very accurate or (not accurate) and moves a lot of good lines to the new layer. Is there a way to:
1- Isolate lines that are between a few degrees of 90 and 270, compare their x coordinates, and if not 0 move to the new layer?
1- Isolate lines that are between a few degree of 0 and 180, compare their y coordinates, and if not 0 move to the new layer?
Any suggestion will be very much appreciated. Application used is AutoCAD 2024 LT
Thank You.
Replies (26)
Message 21 of 27
pullstackautocad
Help can we just change the color of lines which are orthogonal, i mean not straight .
color red . so i could figure out the lines @Kent1Cooper
thankyou
Message 22 of 27
Kent1Cooper
If you mean you want the not-quite-orthogonal Lines changed to red color, but not put on a different Layer, then remove or comment out this line:
(command "_layer" "_new" "NotQuiteOrtho" ""); whether or not it exists already
and change this line:
(entmod (append edata (list '(8 . "NotQuiteOrtho") '(62 . 1))))
to just this:
(entmod (append edata (list '(62 . 1))))
Kent Cooper, AIA
Message 23 of 27
pullstackautocad
sir can i get the lsp file, i am a begineer, it would be very helpful .... thankyou
Message 24 of 27
Kent1Cooper
I would have thought the instructions were easy enough to follow, but see the attached.
Kent Cooper, AIA
Message 25 of 27
pullstackautocad
@Kent1Cooper Idk sir bt Maybe not for my 2018 version.
Message 26 of 27
Kent1Cooper
It works for me, and I can't imagine the version difference would be why it doesn't for you.  But here's a possibility:  Are those "lines" in your drawing LINE objects specifically?  The routine is not written to work with Polylines, if that's what they are.
If that's not the issue, post your drawing file in which it doesn't work.
Kent Cooper, AIA
Message 27 of 27
sharpl
Dear @kentcooper it works, but the out put is  <25 found>, how do we know which ones to fix? The new layer is not formed...
