Find one letter within a closed polyline and append it to a string within the same closed polyline
johnlagasse
johnlagasse
I have a one or two letters as an indicator with a closed polyline. Within that closed polyline is a string of text that I want to append the one or two letters to.  Is there any LISP routine out there already that does this?  I've attached a DWG.  I'm looking to select all the polylines within the drawing and have them all update.  In the case of the DWG I want 10.03.T to end up as 10.03.TB and 10.04.T to end up as 10.04.TAA. Thanks for any assistance.
ВeekeeCZ
DWG seems empty to me.
johnlagasse
I downloaded it and can see two rectangles and text in each.  I resaved it and uploaded it.  Added screenshot.
ВeekeeCZ
Ok, it behaves weird, but see it now.
Is it always short label TEXT and long one MTEXT?
johnlagasse
It can be changed so it's either all Text or all MTEXT
ВeekeeCZ
Ok, here you go. It could be easier if that was a rule.
Anyway.
(vl-load-com)
(defun c:PlineAppendString ( / e i v p e1 e2)
  (if (setq s (ssget '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1))))
    (repeat (setq i (sslength s))
      (if (and (setq v (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x))) (entget (ssname s (setq i (1- i)))))))
	       (setq p (ssget "_WP" v '((0 . "*TEXT"))))
	       (= (sslength p) 2)
	       (setq e1 (entget (ssname p 0)))
	       (setq e2 (entget (ssname p 1)))
	(if (< (strlen (cdr (assoc 1 e1))) 3)
	  (entmod (subst (cons 1 (strcat (cdr (assoc 1 e2)) (cdr (assoc 1 e1)))) (assoc 1 e2) e2))
	  (entmod (subst (cons 1 (strcat (cdr (assoc 1 e1)) (cdr (assoc 1 e2)))) (assoc 1 e1) e1))))))
  (princ)
johnlagasse
Awesome!  Works perfectly.  I just need to close some of the polylines.  THANKS!
