The "After cell" MUST fall within the search range....you have specified a
value outside the range.
The find method takes 8 arguments, you provide only 6.
This worked for me:
(setq myRow (xlm-find myRange ;Where to search
hgt ;String to search for
nil ;After cell
xlc-xlvalues ;Check values
xlc-xlwhole ;match whole or part
nil
nil
nil
nil
wrote in message news:5370521@discussion.autodesk.com...
I have a Visual LSIP program to find a specific value in Excel. I'm able to
open the excel file and point to a specific range. However, I cannot get the
"find" method to work. It always gives me the following error:
"Automation Error - Description not provided"
See the program below.
All variables in the program are assigned a value until it gets to the myRow
variable. The program fails at this point.
Does anyone have any ideas how I can get this to work. Much of the program
was pasted over from some other examples I've found on the internet.
(defun c:extest ()
(vl-load-com)
(setq sheetName "OUTSIDE WALL"
hgt "93")
;;;--- Get the system drive
(setq sysDrive (getenv "systemdrive"))
;;;--- If the excel object library is not found...load it
(if (null Library)
(progn
;;;--- Find out which version we should use
(setq Library
(cond
((findfile (strcat sysDrive "\\Program Files\\Microsoft
Office\\Office\\Excel8.olb")))
Office\\Office\\Excel9.olb")))
Office\\Office\\Excel10.olb")))
Office\\Office\\Excel.exe")))
Office\\Office10\\Excel.exe")))
Office\\Office11\\Excel.exe")))
Office\\Office11\\XL5EN32.OLB")))
;;;--- If the library was found...
(if Library
(progn
;;;--- Strip off
(setq LibVer (substr (vl-filename-base Library) 6))
(cond
((= LibVer "8")(princ "\n Opening Excel Version 8..."))
((= LibVer "9")(princ "\n Opening Excel Version 9..."))
((= LibVer "1")(princ "\n Opening Excel Version 10..."))
((= LibVer "") (princ "\n Opening Excel Version 2000+..."))
((= LibVer "3")(princ "\n Opening Excel Version 2003..."))
(vlax-import-type-library
:tlb-filename Library
:methods-prefix "XLM-"
:properties-prefix "XLP-"
:constants-prefix "XLC-"
(alert "Excel Object Library was not found!\n\nLook inside the
XL_Readme.txt file for HELP.")
;;;--- If an excel application is not loaded, proceed...
(if (null myApp)
(progn
;;;- Select an Excel workbook
(setq fileName "c:/cad/support/tafco/shear sizes/shear sizes.xls")
;;;--- Verify the path to the file
(setq fileName(findfile fileName))
;;;--- Set the default file name globally for next use
(setq oldFileName fileName)
(princ "\n Opening Excel file...")
;;;--- If Excel...
(if(setq myapp(vlax-get-or-create-object "Excel.Application"))
(progn
;;;--- Open the workbook
(vlax-invoke-method (vlax-get-property myapp 'WorkBooks) 'Open
fileName)
;;;--- Set it to invisible mode
(vla-put-visible myApp 1)
;;;--- Get the workbooks object
(setq myWBooks(vlax-get myApp "Workbooks"))
;;;--- Open the excel file
(setq myWBook(vla-open myWBooks fileName))
;;;;--- Get the sheets object
(setq mySheets(vlax-get myWBook "Sheets"))
;;;--- Get the selected worksheet
(setq mySht(vlax-get-property mySheets 'Item sheetName))
;;;--- Make the selected worksheet active
(vlax-invoke-method mysht "Activate")
(setq myRange (xlp-get-range mysht "B4:B100"))
(setq aftRange (xlp-get-range mysht "B3"))
;;Search 1st column
;; Use FIND method of Excel with defaults
aftRange ;After cell
nil
nil
(cond
(not(vlax-object-released-p myApp))
(vlax-invoke-method myApp 'QUIT)
(vlax-release-object myApp)
);end function
