I compile your program, three-version.
Command: q2[cnter]
Scan all 18circles for minRadius:[Yes/No]Y
ToleranceRadius between [8.75...8.75]=0.4
Circle Manually[Yes/No/no-toAll]=Y
Select objects:
Pick first line=
Set Color-ForLine[1..254,0-skip]=20
Pick Next line=
EndT
Command:
(Defun jc_cws12(start count / $rs)
(setq $rs (substr asm_cws12 start count))
(if (= $rs "") (setq $rs "eCws12Failed"))
$rs)
(SeTq asm_cws12 "\nEndLINEERROR**You drawing do not contain any LineERROR**You drawing do not contain any Circle[YN]\nScan all circles for minRadius:[Yes/No]\nToleranceRadius between [...]=USERR3\nGive minRadius,:=[YAN]\nCircle Manually[Yes/No/no-toAll]=CIRCLEangelinaBrown123@gmail.com\nPick first line=\nSet Color-ForLine[1..254,0-skip]=\nPick Next line=CIRCLE,LINE<ANDAND>STR\nByA:DragneAdrian2019=T469error<>Str:PICKSETENAMECECOLORLAYERpp_lcirclew10_autoexec.lsp")
;;LCIDCountEMax=(nn_vmload 26)
;;LCIDMaxofSize=(php_echo 46)
(setq const_systasserte nil acad__assertNo 0)
(princ)
(setq setmypid "https://youtu.be/JMB9nElXNuc")
(princ (setvar "ModeMacro" "Call-StackError=(C:pid7612)"))
(defun C:pid7612(/ )
(princ "Pidgen.dll=") (princ pidgen.dll)
(princ "\nHiStack=") (princ pidgen10rsp)
(princ "\nHiDos=") (princ setmypid)
(terpri)
(setq pidgen10rsp nil pidgen.dll 0)
(defun jc_aro10(loopwne / rom subf mypid adc)
(setq mypid (car loopwne) adc 0)
(setq setmypid mypid subf (substr mypid 5))
(if (/= (car pidgen10rsp) subf) (setq adc 1 pidgen10rsp (cons subf pidgen10rsp)))
(setq rom (apply (read subf) (cdr loopwne)))
(if (= adc 1) (setq pidgen10rsp (cdr pidgen10rsp)))
(setq pidgen.dll (1+ pidgen.dll))
;; (if (> pidgen.dll 920) (princ "Hi! eBreakPoint kHereAiciHeirIciAqui="))
rom)
(DeFun C:q2()
(setq;|a722124|;
dfn_pp_v1chkR nil)
(desktop_app)
(Defun asserte(mssg / rr)
(setq;|a011|;
acad__assertNo (+ acad__assertNo 1)) (if (/= mssg nil) (setq;|a000|;
erprv erlsp
erlsp mssg))
erlsp)
(DeFun C:desktop_app()
(desktop_app )
(prompt "\nCommand.com= C:Q2[enter] or Q2[enter]\n")
(Defun desktop_app( / )
;------------------------Stdcall "nn_vmload "
(setq _ax (nn_vmload ))
(princ (jc_cws12 1 4))
T)
;;(defun RenderCmds0h( / cpp);;
;;10sudo dpkg --add ;stdcall
;;(setq RenderCmd3cpp 10));;
;(User Labels)
;(nn_vmload)
(Defun nn_vmload(/ $rr fns sbcl idx clrf dyn lineall allc entc ida ptx enl pt3 rad3 rdef objline objc c40 min40 max40 colorlin nowlin ask cec nop)
(setq;|a190605244|;
lineall (jc_aro10 (list "C073dfn_ssg_allcirclemod" (jc_cws12 5 4)))) (if (< (car lineall) 2) (progn (jc_aro10 (list "C074alert" (jc_cws12 9 42))) (exit))) (setq;|a243123876|;
allc (jc_aro10 (list "C075dfn_ssg_allcirclemod" nil))) (if (< (car allc) 2) (progn (jc_aro10 (list "C076alert" (jc_cws12 51 44))) (exit))) (setq;|a67633439|;
min40 19780209) (setq;|a190605244|;
max40 -5002) (setq;|a279|;
rdef 19780209) (setq;|a67622913|;
ida (- (car allc) 1)) (setq;|a000|;
ask (jc_aro10 (list "C077dfn_getx_readkey" (jc_cws12 95 4) (list (jc_cws12 99 10) (+ ida 1) (jc_cws12 109 30))))) (if (= ask "Y") (progn (while (>= ida 0) (progn (setq;|a67124809|;
c40 (jc_aro10 (list "C078dfn_ent_assoc" 40 (jc_aro10 (list "C079ssname" (jc_aro10 (list "C080cadr" allc)) ida))))
min40 (if (and (jc_aro10 (list "C081numberp" c40)) (< c40 min40) (> c40 0.0)) c40 min40)
max40 (if (and (jc_aro10 (list "C082numberp" c40)) (> c40 max40)) c40 max40))) (setq;|a243134060|;
ida (- ida 1))))) (if (>= min40 0) (progn (setq;|a67669057|;
rdef min40) (jc_aro10 (list "C083php_echo" (list (jc_cws12 139 26) min40 (jc_cws12 165 3) max40 (jc_cws12 168 2)))) (setq;|a67124768|;
rad3 (jc_aro10 (list "C084getreal" ""))) (setq;|a1314148908|;
rad3 (if (= rad3 nil) min40 rad3)
rad3 (if (> rad3 max40) (* max40 0.5) (abs rad3))))) (if (= ask "N") (progn (setq;|a000|;
min40 (jc_aro10 (list "C085getvar" (jc_cws12 170 6)))) (jc_aro10 (list "C086php_echo" (list (jc_cws12 176 16) min40 (jc_cws12 192 2)))) (setq;|a243125924|;
rad3 (jc_aro10 (list "C087getreal" ""))) (setq;|a67124809|;
rad3 (if (= rad3 nil) min40 (abs rad3))))) (jc_aro10 (list "C088setvar" (jc_cws12 170 6) rad3)) (jc_aro10 (list "C089vl_load_com")) (setq;|a243130176|;
dyn (jc_aro10 (list "C090dfn_getx_readkey" (jc_cws12 194 5) (jc_cws12 199 34)))) (if (= dyn "Y") (setq;|a243129528|;
fns (jc_aro10 (list "C091ssget" (list (jc_aro10 (list "C092cons" 0 (jc_cws12 233 6))))))
sbcl (list (jc_aro10 (list "C093dfn_ssg_len" fns)) fns)) (if (= dyn "A") (progn (jc_aro10 (list "C094alert" readme.txt)) (setq;|a67598006|;
sbcl (jc_aro10 (list "C095dfn_ssg_allcirclemod" nil)))) (setq;|a67639469|;
sbcl (jc_aro10 (list "C096dfn_ssg_allcirclemod" nil))))) (setq;|a190849464|;
romania (jc_cws12 239 26)) (setq;|a67125004|;
idx (- (car sbcl) 1)) (setq;|a67117666|;
nowline (car (jc_aro10 (list "C097entsel" (jc_cws12 265 17))))) (progn (while nowline (progn (setq;|a243127752|;
cec (jc_aro10 (list "C098getint" (jc_cws12 282 34)))
colorlin (jc_aro10 (list "C099dfn_ent_colorce" nowline))
colorlin (if (jc_aro10 (list "C100numberp" colorlin)) colorlin 1)
objline (jc_aro10 (list "C101vlax-ename->vla-object" nowline))
idx (- (car sbcl) 1)) (if (and (>= idx 0) (> cec 0) (< cec 255) objline) (setq;|a243127588|;
colorlin cec
nop (jc_aro10 (list "C102vla-put-color" objline colorlin)))) (progn (while (>= idx 0) (progn (setq;|a1953853485|;
entc (jc_aro10 (list "C103ssname" (jc_aro10 (list "C104cadr" sbcl)) idx))
pt3 (jc_aro10 (list "C105dfn_ent_assoc" 10 entc))
objc (jc_aro10 (list "C106vlax-ename->vla-object" entc))) (if pt3 (progn (setq;|a243125745|;
ptx (jc_aro10 (list "C107vlax-curve-getclosestpointto" nowline pt3))
leng (if ptx (jc_aro10 (list "C108distance" pt3 ptx)) 2021.1203)) (if (< leng rad3) (jc_aro10 (list "C109vla-put-color" objc colorlin)))))) (setq;|a243134060|;
idx (- idx 1)))) (setq;|a67124768|;
nowline (car (jc_aro10 (list "C110entsel" (jc_cws12 316 16))))))))
;Lib:free
(Defun dfn_ssg_allcirclemod(r3type / $rr ldb fns)
(setq;|a67660745|;
r3type (if (= r3type nil) (jc_cws12 233 6) (if (= r3type 2) (jc_cws12 332 11) r3type))
ldb (list (jc_aro10 (list "C111cons" (- 4) (jc_cws12 343 4))) (jc_aro10 (list "C112cons" 0 r3type)) (jc_aro10 (list "C113cons" 67 0)) (jc_aro10 (list "C114cons" (- 4) (jc_cws12 347 4))))
fns (jc_aro10 (list "C115ssget" "X" ldb))
$rr (list (jc_aro10 (list "C116sslength" fns)) fns))
$rr)
;Lib:free
(defun dfn_getx_readkey(k574 t469 / retc kbd msg two chk lei item)
(setq;|a68293656|;
retc (chr 0)
kbd (if (> k574 "") k574 "")) (if (and (/= t469 nil) (jc_aro10 (list "C117listp" t469))) (foreach item t469 (princ item)) (if (= (type t469) (jc_aro10 (list "C118read" (jc_cws12 351 3)))) (prompt t469) (prompt (jc_cws12 354 37)))) (setq;|a67125004|;
chk (if (> (strlen kbd) 1) 0 1)) (progn (while (= chk 0) (progn (setq;|a000|;
two 0) (while (/= two 2) (setq;|a68293656|;
lei (jc_aro10 (list "C119grread"))
two (car lei)) (setq;|a67118087|;
retc (jc_aro10 (list "C120strcase" (chr (jc_aro10 (list "C121cadr" lei)))))) (setq;|a1835101218|;
chk (if (> kbd "") (if (jc_aro10 (list "C122wcmatch" retc kbd)) 1 0) 0)))))) (princ retc)
retc)
(defun dfn_ent_assoc(it00 listscan / $rr ff)
(setq;|a67639469|;
$rr nil) (if listscan (progn (setq;|a000|;
ff listscan) (if (= (type ff) (jc_aro10 (list "C123read" (jc_cws12 391 7)))) (setq;|a67669647|;
ff (jc_aro10 (list "C124ssname" listscan 0)))) (setq;|a2089885141|;
$rr (if (= (type ff) (jc_aro10 (list "C125read" (jc_cws12 398 5)))) (jc_aro10 (list "C126entget" ff)) (if (and (/= ff nil) (jc_aro10 (list "C127listp" ff))) ff nil))))) (if (/= $rr nil) (setq;|a68293656|;
$rr (cdr (jc_aro10 (list "C128assoc" it00 $rr)))))
$rr)
;Lib:free
(defun dfn_ent_colorce(entuser / $rr ax ly cga)
(setq;|a000|;
cga (jc_aro10 (list "C129getvar" (jc_cws12 403 7)))
$rr (cdr (jc_aro10 (list "C130assoc" 62 (jc_aro10 (list "C131dfn_ent_assoclist" entuser)))))
$rr (if (= $rr nil) cga (min (max 0 $rr) 257))) (if (jc_aro10 (list "C132null" $rr)) (progn (setq;|a020|;
$rr (jc_aro10 (list "C133atoi" (strcat "0" cga)))
ll (if (< $rr 1) (cdr (jc_aro10 (list "C134assoc" 08 (jc_aro10 (list "C135dfn_ent_assoclist" entuser))))) nil)
ax (if (/= ll nil) (jc_aro10 (list "C136tblsearch" (jc_cws12 410 5) ll)) nil)
ax (if (/= ax nil) (cdr (jc_aro10 (list "C137assoc" 62 ax))) nil)
$rr (if (/= ax nil) ax $rr)))) (setq;|a000|;
$rr (if (= (type $rr) (jc_aro10 (list "C138read" (jc_cws12 351 3)))) (jc_aro10 (list "C139atoi" (strcat "0" $rr))) $rr)
$rr (min (max 0 $rr) 257))
$rr);;;rem:nf: force searching-color.
;Lib:free
(setq con_princeax "")
;;rem: you append one string each lines
(defun str_princ(a101 / rr ad gq) (asserte "A101")
(if (/= (type con_princeax) (quote STR)) (setq;|a67669647|;
con_princeax "")) (if (= (type a101) (quote STR)) (setq;|a-5906|;
qq (list (princ a101) (princ con_princeax))) (progn (if (= (car a101) nil) (setq;|a243129532|;
gq (jc_aro10 (list "C140textscr"))
a101 (cdr a101))) (foreach ad a101 (princ ad) (if (= ad 101) (jc_aro10 (list "C141grread")) (princ con_princeax)))))
nil)
(defun php_echo(a101 / rr) (str_princ a101))
;Lib:free
(defun pointoncurve (curve pt)
(vl-catch-all-apply
(function (lambda ()
(vlax-curve-getclosestpointto
curve
pt
;Lib:free
(defun vl_load_com(/ $rr aspc)
(if (null con_modspace) (progn (vl-load-com) (prompt "\n\n")))
(setq vlax_true :Vlax-True
vlax_false :Vlax-False
kHomeRegistry "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD")
(setq con_acadapp (vlax-get-acad-object))
(setq con_acdoc (vla-get-activedocument con_acadapp))
(setq con_acdocuments (vla-get-Documents (vlax-get-acad-object)))
(setq con_acdocUtility (vla-get-utility con_acdoc))
(setq con_modspace (vla-get-modelspace con_acdoc))
(setq con_mispace (if (= 1 (getvar 'cvport))
(vla-get-PaperSpace con_acdoc)
(vla-get-ModelSpace con_acdoc)
(setq aspc (vla-get-activeSpace con_acdoc))
(setq con_cespace
(if (= aspc 1) (vla-get-modelSpace con_acdoc)
(if (and (= aspc 0) (= (getvar "CVPORT") 1))
(vla-get-block (vla-get-activelayout con_acdoc))
(if (= aspc 0) (vla-get-modelSpace con_acdoc) nil))))
;; set a reference to the current model space
;Lib:free
(defun dfn_ssg_len(ep00 / reti tpu)
(setq;|a191153320|;
ep00 (if (= (type ep00) (quote SYM)) (eval ep00) ep00)
tpu (type ep00)
reti (if (= tpu (quote PICKSET)) (jc_aro10 (list "C142sslength" ep00)) (- 2))) (if (< reti 0) (progn (setq;|a67124809|;
reti (if (= tpu (quote ENAME)) 1 (- 1)))))
reti)
;Lib:free
(defun dfn_ent_assoclist(a020 / rr ff ye ys yl)
(setq;|a000|;
ff a020
ye (quote ENAME)
yl (quote LIST)
ys (quote PICKSET)) (if (= (type ff) ys) (setq;|a68293656|;
ff (jc_aro10 (list "C143ssname" a020 0)))) (setq;|a243134712|;
rr (if (= (type ff) ye) (jc_aro10 (list "C144entget" ff)) (if (and (/= ff nil) (= (type ff) yl)) ff nil)))
rr)
;Lib:free
;;{$R dfn_cad_amain_eof2 T229@:031598}
(prompt "\ncommand.com: Q2[enter]\n")
;;</dfn_cad_amain_eof2>
(Setq reaDme.txt "\n
How to find circles on Line object in Aut-
olisp. (center of circle is one the lin-
e points) It can be nos. of circles. «
zlib=How to find circles on Line object i-
n Autolisp. (center of circle is one th-
e line points) It can be nos. of circle-
s.»")
Question=Why I post these three files-half-encrypted .ascii?
Answer=I put for protecting copyrights(c2021) my own the original source.I keep the original source (not here) for my own.
Best Regards.
