Find Circles and add additional circle
inulobo
Message 1 of 11
inulobo
I am trying to find all circles of a particular diameter then add an additional circle of a particular diameter to the center of each circle. How do I go about this? Using the code below for selecting all circles.
(defun c:CSC  (/ cEnt ssgrip)
  (setq tol 0.05)  ; <<-- Tolerance
  (if (setq cEnt (car (entsel "\nSelect Circle: ")))
    (progn
      (setq rad (cdr (assoc 40 (entget cEnt))))
      (sssetfirst nil
        (ssget "_X"
               (list '(0 . "CIRCLE")
                     '(-4 . ">=")
                     (cons 40 (- rad tol))
                     '(-4 . "<=")
                     (cons 40 (+ rad tol)))))
      (alert (strcat "Radius = " (rtos rad 2 2))))
    (princ "\n<!> Nothing Selected <!>"))
  (princ))
Replies (10)
Message 2 of 11
pbejse
What will be the radius of the additional circle? via user prompt? or based on the current radius of the selected circles?
Message 3 of 11
inulobo
I would prefer a user prompt or even the ability to add a default value.
Message 4 of 11
pbejse
Using most parts of the orignal lisp
(defun c:CSC  (/ cEnt rad ss i ent)
  (setq Nrad (cond
	((getdist (strcat "\nEnter Radius"
                 (if Nrad (strcat " <" (rtos Nrad) ">: ") ": ")
                            )))(Nrad))
  (if (and
	(setq ss (ssget	"_X"
			      '(-4 . ">=")
			      '(-4 . "<=")
	);and
    (repeat (setq i (sslength ss))
	(setq ent (entget (ssname ss (setq i (1- i)))))
    	  (entmakex
	    (subst (Cons 40 Nrad) (assoc 40 ent) ent))
  (princ)
 HTH
Message 5 of 11
inulobo
Thank you! If I wanted to use this for diameters instead of radiuses what do I have to do? I am not too familiar with lisp.
Message 6 of 11
pbejse
You mean prompt for Diameter instead of radius?
Change this
(entmakex
to
(entmakex
	    (subst (Cons 40 (* 0.5 Nrad)) (assoc 40 ent) ent))
Also change the radius to Diameter on the prompt.
HTH
Message 7 of 11
inulobo
Thanks. I was wondering were it took that into account.
Message 8 of 11
hak_vz
Try this
(defun c:circleInCircle ( / r f sel_list fil ss i)
(setq r (getreal "\nEnter circle diameter to insert: "))
(setq i 0)
(while (> (strlen (setq f (getstring (strcat "\nEnter " (itoa (setq i (1+ i))) ". radius selection filter: ")))) 0)
	(setq fil (cons (list (substr f 1 1)(atof (substr f 2))) fil))
(setq sel_list (list(cons -4 "<and")))
(foreach e fil (setq sel_list (append sel_list (list(cons -4 (car e)))))(setq sel_list (append sel_list (list(cons 40 (cadr e))))))
(setq sel_list (append sel_list (list(cons -4 "and>"))))
(setq ss (ssget "X" (append (list (cons 0 "CIRCLE")) sel_list)))
(cond
	((and ss)
		(setvar 'cmdecho 0)
		(setq i -1)
		(while (< (setq i (1+ i)) (sslength ss))
			(setq c (cdr (assoc 10 (entget (ssname ss i)))))
			(command "_.circle" "_non" c r)
		(setvar 'cmdecho 0)
(princ)
Command: CIRCLEINCIRCLE
Enter circle diameter to insert: 2
Enter 1. radius selection filter: >3
Enter 2. radius selection filter: <8
Enter 3. radius selection filter:
Miljenko Hatlak
Message 9 of 11
inulobo
I don't understand exactly what you did here. Ill either be all in radius or all in diameter. Are you trying to set a search to find radius or diameter within that range?
Message 10 of 11
hak_vz
Radius. You can modify it to select diameter as @pbejse  has shown. Code asks you to enter radius of a circle to be inserted an then you can enter one or more filters to select circle candidates. In my example I selected all circles with radius greater than 3 and smaller than 8.
Miljenko Hatlak
Message 11 of 11
inulobo
Thank you!
