Find center by 4 points
Lukasvop1
Message 1 of 26
Lukasvop1
Hi guys, I realize I need tool like this, can you help?
This lisp "FC" should find center between 4 picked points and place block there.
-In lisp should be path to the block.
-Would be greate if there will be option set Scale factor of the block (similar like BREAKLINE (Express Tool)).
@komondormrex
Accepted solutions (4)
Replies (25)
Message 21 of 26
komondormrex
hey there,
just select entities to set center of theirs bounding box.
(defun c:center_of_bounding_box (/ ename_sset llc urc b_llc b_urc block_size)
	(setq init_block_size (if (null init_block_size) (setq init_block_size '(10)) init_block_size))
	(if (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) "D_Cross")))
		(progn
			(vla-addline (vla-add (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (vlax-3d-point '(0 0 0)) "D_Cross")
						 (vlax-3d-point '(-0.5 -0.5)) (vlax-3d-point '(0.5 +0.5))
						 (vlax-3d-point '(-0.5 +0.5)) (vlax-3d-point '(0.5 -0.5))
	(if (setq ename_sset (ssget))
		(progn
			(foreach object (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ename_sset))))
				(vla-getboundingbox object 'llc 'urc)
				(setq llc (vlax-safearray->list llc)
					  urc (vlax-safearray->list urc)
					  b_llc (if (null b_llc) llc (list (min (car b_llc) (car llc)) (min (cadr b_llc) (cadr llc))))
					  b_urc (if (null b_urc) urc (list (max (car b_urc) (car urc)) (max (cadr b_urc) (cadr urc))))
			(setq block_size (getreal (strcat "\nEnter block sizes <" (rtos (nth 0 init_block_size)) ">: "))
				  block_size (if (null block_size) (nth 0 init_block_size) block_size)
				  init_block_size (list block_size)
			(vla-insertblock (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
							 (vlax-3d-point (mapcar '* '(0.5 0.5) (mapcar '+ b_urc b_llc)))
							 "D_Cross" block_size block_size block_size 0
	(princ)
Message 22 of 26
calderg1000
Regards @Lukasvop1
Try this code, to get the average point of abscissa and ordinate, you can select the points in any order...
;;;___
(defun c:pxy(/ p1 p2 p3 p4 pc i j m n)
  (setvar 'pdmode 3)
  (setvar 'pdsize 0.5)
  (setq p1 (getpoint "\nPick Point 1")
        p2 (getpoint p1 "\nPick Point 2")
        p3 (getpoint p2 "\nPick Point 3")
        p4 (getpoint p3 "\nPick Point 4")
  (setq lp (vl-sort (list p1 p2 p3 p4) '(lambda (a b) (< (car a) (car b)))))
  (entmakex (list '(0 . "point")
                  (cons 10
                        (list (apply '(lambda (i j) (* (+ i j) 0.5))
                                     (list (caar lp) (car (cadddr lp)))
                              (apply '(lambda (m n) (* (+ m n) 0.5))
                                     (list (cadr (cadr lp)) (cadr (caddr lp)))
Carlos Calderon G
>Did you find this post helpful? Feel free to Like this post.
Message 23 of 26
Lukasvop1
Wow, this is perfect.
Message 24 of 26
Lukasvop1
Thank you
Message 25 of 26
calderg1000
Saludos @Lukasvop1
Here my version to find the geometric center, selecting the entities that define the bounding box...
;;;___
(defun c:pxys (/ lobj j pmx pmn lp lf lx ly pmin pmax)
  (setvar 'pdmode 3)
  (setvar 'pdsize 0.2)
  (setq
    lobj (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "*"))))))
  (foreach j lobj
    (vla-getboundingbox (vlax-ename->vla-object j) 'pmx 'pmn)
    (setq lp (list (vlax-safearray->list pmx)
                   (vlax-safearray->list pmn)
    (setq lf (cons lp lf))
  (setq lf   (apply 'append lf)
        lx   (vl-sort lf '(lambda (x y) (< (car x) (car y))))
        ly   (vl-sort lf '(lambda (x y) (< (cadr x) (cadr y))))
        pmin (list (car (car lx)) (cadr (car ly)))
        pmax (list (car (last lx)) (cadr (last ly)))
  (entmakex
          (cons 10
                (mapcar '(lambda (z k) (* (+ z k) 0.5)) pmin pmax)
  (princ)
Carlos Calderon G
Message 26 of 26
Lukasvop1
Perfect, thank you.
