Filter list of objects based on their xdata
lminnema
lminnema
I need a function that I can supply with a list of vla objects and a specific number stored in xdata group 1070,  and it will return a list of just the vla objects with that specific number stored. For example a list of 5 objects: who have numbers 1, 3, 2, 3, and 5 stored to them respectively, I would say specInstnce is 3, it would return a list containing just objects 2 and 4. I have also supplied the function that I am using that takes an object's ename or vla-object and returns the value that is stored in 1070.
(defun getxdata (obj)
  (cond
    ((= 'VLA-object (type obj))
     (cdr
       (assoc 1070
              (cdr
                (car
                  (cdr
                    (assoc -3
                           (entget (vlax-vla-object->ename obj) (list oneline:app))
    ((= 'ENAME (type obj))
     (cdr (assoc 1070 (cdr (car (cdr (assoc -3 (entget obj (list oneline:app))))))))
(defun getspecificowners (vlaObjects specInstnce)
 (mapcar '(lambda (x) (if (= (getxdata x) specInstnce))) vlaObjects)
 The first function here works fine, but it is probably not very well written. The second function here does not work at all and I don't think I'm anywhere close with the code currently written.
Thanks in advance.
Kent1Cooper
.... The second function here does not work at all ....
There's no "then expression" for that (if) function.  I think you need:
.... (if (= (getxdata x) specInstnce) [what-to-do-if-it-matches])) ....
Presumably what-to-do would be to put it into another list of qualifying ones only, for whatever you need to do with them.  Or maybe if it doesn't match, remove it from the vlaObjects list if you don't need to retain the complete list but only the qualifying ones.
Kent Cooper, AIA
BlackBox_
@lminnema *IF* I understood Kent's apt post correctly, something like this may help:
(defun getspecificowners (vlaObjects specInstnce / matchingObjects)
  (mapcar
    (function
      (lambda (x)
          (setq matchingObjects (cons x matchingObjects))
    vlaObjects
  matchingObjects
Note: You didn't post a sample drawing, so untested.
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
komondormrex
check the following function. outputs list of objects with '(1070 . specific_number) xdata group or nil.
(defun filter_specific_xdata_object (object_list specific_number oneline:app / target_object)
	(vl-remove nil
	  	   (mapcar '(lambda (object) (if (vl-some '(lambda (xdata_group) (equal (cons 1070 specific_number) xdata_group))
					         	(cdadr (assoc -3 (entget (vlax-vla-object->ename (setq target_object object)) (list oneline:app))))
				                 target_object
		            object_list
object_list - list of vla objects to be checked
specific_number - integer in xdata 1070 group
oneline:app - xd application name
lminnema
Thanks for the help, it took me a while to get the rest of the program working, but this was a major help.
BlackBox_
@Kent1Cooper gave the idea, I just helped. 🍺
Cheers
