Filter and erase then purge text
I am trying to erase all text objects and all the block objects from a drawing then purge all unused layers from the drawing. I have named filters set up to select the objects I need.
(defun C:CleanDXF ()
(command "erase" "window" "607.454,4976.357" "613.677,4997.599" "") ;erases an unneeded legend
(command "zoom" "e") ;zoom to fit all objects into the window
(command "filter" "window" "0,0" "9999999,9999999" "" "erase" ""      ;if I close the routine before the "" here it works
                    "filter" "window" "0,0" "9999999,9999999" "" "erase" "")    ;Adding the second filter command breaks it
);defun
Here is the command history from when I run the routine.
Command: CLEANDXF
erase
Select objects: window
Specify first corner: 607.454,4976.357 Specify opposite corner: 613.677,4997.599 0 found
Select objects:
Command: zoom
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] : e
Command: filter Applying filter to selection.
Specify first corner: 0,0 Specify opposite corner: 9999999,9999999 12 found
Select objects: Exiting filtered selection.
Command: erase
Select objects:
Command: erase
Select objects:
Command: nil
Is there a way to automate the named filter selection?
Why is erase not seeing the selected objects?
What can I do to fix this routine?
dlanorh
Try the attached, It does away with the filter command as you can create a selection set using ssget with a filter list.
This lisp will ask if want to delete all text and block objects in Model space, Paper space (all tabs) or Both (default is Both)
(defun c:cleandxf ( / sv_lst sv_vals ans ss)
  (setq sv_lst (list 'dynmode 'dynprompt)
        sv_vals (mapcar 'getvar sv_lst)
  );end_setq
  (mapcar 'setvar sv_lst (list 3 1))
  (initget "Both Model Paper")
  (setq ans (cond ( (getkword "Select Space to delete all Text and Blocks : [Both/Model/Paper] <Both>")) ("Both")))
  (cond ( (= ans "Model") (setq filter (list '(0 . "INSERT,TEXT") (cons 410 "Model"))))
        ( (= ans "Paper") (setq filter (list '(0 . "INSERT,TEXT") (cons 410 "Paper"))))
        (t (setq filter (setq filter (list '(0 . "INSERT,TEXT")))))
  );end_cond
  (setq ss (ssget "_X" filter))
  (repeat (setq cnt (sslength ss)) (entdel (ssname ss (setq cnt (1- cnt)))))
  (mapcar 'setvar sv_lst sv_vals)
  (princ)
);end_defun
I am not one of the robots you're looking for
dlanorh
Just noticed that the posted lisp is wrong.  This is correct.
  );end_setq
        ( (= ans "Paper") (setq filter (list '(0 . "INSERT,TEXT") (cons 410 "~Model"))))
  );end_cond
  (princ)
);end_defun
Once again find and replace is overzealous 🙄 ☹️
john.uhden
"~Model"
Very clever... every layout except "Model"
John F. Uhden
devitg
Hi John , nice answer about
"~Model"
I was wonder what it was???
