Fillet multiple polyline all at once by lisp
Message 1 of 31
Help me please,
Anybody know how to fillet selected polylines all at once by lisp.
Replies (30)
Message 21 of 31
urban33
Community Visitor
Community Visitor
Fantastic code.
Can I use the same for chamfer?
Thanks.
Message 22 of 31
Kent1Cooper
@urban33 wrote:
.... Can I use the same for chamfer? ....
You apparently have not looked through the entire topic.  See Message 17.
Kent Cooper, AIA
Message 23 of 31
paliwal222
Sir,
My problem is solved with "Fillet multiple Polyline" code.
this time I fillet multiple polyline approx. a bunch of 250, and explode them.
put "arc" in  "arc"  layer.
and change my poly line according surveyor road type, (four type of road)
isolate road layer type -1 + arc layer then join them,
isolate road layer type -2 + arc layer then join them, (repeat again with arc layer is isolate always four times)
one by one by four time I make arc with road with different layer.
Thanks.
Message 24 of 31
paliwal222
Sir
My problem is solved with FilletMultiplePolylines.lsp
its not necessary to break arc at mid point.
Thanks.
Message 25 of 31
midorikawa.mitsunobu
"I tried creating a code to input the fillet radius at the beginning, referring to the Lisp program you created. However, since it requires input every time, what should I do to make it possible to retain the previously input value in the input field?"
(defun C:FMP ;Fillet Multiple Polylines
       (/ plss n radius)
  (setq radius (getreal "\Enter fillet radius: "))
  (if (null radius)
    (progn
      (princ "\nError:Fillet radius is not inputted。")
      (exit)
    (if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE"))))
      (repeat (setq n (sslength plss))
(command "_.fillet"
"_polyline"
"R"
radius
(ssname plss (setq n (1- n)))
    ) ; if
  ) ; if
  (princ)
) ; defun
"It was already resolved with FilletMultiplePolylines.lsp.
Thank you very much."
Message 26 of 31
Sea-Haven
I would use a less obvious name than radius like xradiusx, try this
(if (null xradiusx)
(setq xradiusx (getreal "\Enter fillet radius: "))
Take the radius out of your localising of variables (/ plss n radius)
Message 27 of 31
Kent1Cooper
@midorikawa.mitsunobu wrote:
.... what should I do to make it possible to retain the previously input value in the input field?"....
You should use the version called FilletMultiplePolylines.lsp at Message 12.
Kent Cooper, AIA
Message 28 of 31
Thank you very much
Message 29 of 31
Thank you very much
Message 30 of 31
I am currently studying LISP. Thank you in advance for your continued support.
Message 31 of 31
I am currently studying LISP. Please continue to teach me in the future.
