fillet and join lines
leticia.campanelli
Message 1 of 13
leticia.campanelli
Hi there,
I am wondering if someone has a lisp for fillet and join lines.
Replies (12)
Message 2 of 13
Kent1Cooper
I would guess that such a thing is out there somewhere for the Searching [but I'll let you Search].
But if not, are you talking about only Line objects specifically, or anything Filletable?  And at any radius including zero [meaning there may or may not be a new Arc resulting from the command]?
Kent Cooper, AIA
Message 3 of 13
Moshe-A
@leticia.campanelli  hi,
by saying join lines you mean that after fillet you want the outcome to be a pline?
Moshe
Message 4 of 13
pendean
Community Legend
Community Legend
@leticia.campanelli Fillet and Join together as one LISP? Please explain and show circumstances where you need that please, so we have a better idea of your goals here.
Otherwise... F is for FILLET and J is for JOIN, what more do you need those to do, please elaborate and be very specific.
Message 5 of 13
Sea-Haven
Like others Join into a pline then, Fillet, Polyline, for common radius in all segments.
Message 6 of 13
leticia.campanelli
Hi
sorry I wasn't clear.
I meant selecting lines fillet with zero radius and join them in one go so it turns into a Pline.
thanks
Message 7 of 13
pendean
Community Legend
Community Legend
@leticia.campanelli wrote:
Hi
thanks
How would the LISP know which ends of lines to FILLET to keep? Is there a static criteria that always shows up in your files?
What is it you are trying to create with this tool: can you show us a bunch of screenshots before/after type?
Message 8 of 13
CADaSchtroumpf
Does this meet your need?
(defun det_wh (px p1 p2 / v1 v2 det_or)
  (setq
    v1 (mapcar '- p2 p1)
    v2 (mapcar '- px p1)
  (if (> (apply '(lambda (x1 y1 z1 x2 y2 z2) (- (* x1 y2) (* y1 x2))) (append v1 v2)) 0.0) 1 -1)
(defun k_th (p1 p2 c / k)
  (setq k (/ c (distance p1 p2)))
  (mapcar '+ (mapcar '* (mapcar '- p2 p1) (list k k k)) p1)
(defun c:fillet0lw ( / ps1 ps2 js1 js2 dxf_210 pt_lst pt l3)
  (princ "\nSelect the first line: ")
  (while (or (null (setq js1 (entsel))) (/= (cdr (assoc 0 (entget (car js1)))) "LINE")))
  (princ "\nSelect the second line: ")
  (while (or (null (setq js2 (entsel))) (/= (cdr (assoc 0 (entget (car js2)))) "LINE")))
  (setq
    ps1 (trans (cadr js1) 1 0)
    ps2 (trans (cadr js2) 1 0)
    js1 (entget (car js1))
    js2 (entget (car js2))
    dxf_210 (cdr (assoc 210 js1))
    pt_lst (list (cdr (assoc 10 js1)) (cdr (assoc 11 js1)) (cdr (assoc 10 js2)) (cdr (assoc 11 js2)))
    pt_lst (mapcar '(lambda (x) (trans (trans x (cdar js1) 1) 1 dxf_210)) pt_lst)
    pt (inters (car pt_lst) (cadr pt_lst) (caddr pt_lst) (cadddr pt_lst) nil)
  (cond
    (pt
      (if (eq (det_wh (cadddr pt_lst) (car pt_lst) (cadr pt_lst)) (det_wh (caddr pt_lst) (car pt_lst) (cadr pt_lst)))
        (if (> (distance pt (caddr pt_lst)) (distance pt (cadddr pt_lst)))
          (setq l3 (list pt (caddr pt_lst)))
          (setq l3 (list pt (cadddr pt_lst)))
        (if (eq (det_wh ps2 (car pt_lst) (cadr pt_lst)) (det_wh (caddr pt_lst) (car pt_lst) (cadr pt_lst)))
      (if (eq (det_wh (cadr pt_lst) (caddr pt_lst) (cadddr pt_lst)) (det_wh (car pt_lst) (caddr pt_lst) (cadddr pt_lst)))
        (if (> (distance pt (car pt_lst)) (distance pt (cadr pt_lst)))
          (setq l3 (cons (car pt_lst) l3))
          (setq l3 (cons (cadr pt_lst) l3))
        (if (eq (det_wh ps1 (caddr pt_lst) (cadddr pt_lst)) (det_wh (car pt_lst) (caddr pt_lst) (cadddr pt_lst)))
      (entdel (cdar js1))
      (entdel (cdar js2))
      (entmake
        (append
          (list
            '(0 . "LWPOLYLINE")
            '(100 . "AcDbEntity")
            (assoc 67 js1)
            (assoc 410 js1)
            (assoc 8 js1)
            (if (assoc 62 js1) (assoc 62 js1) (cons 62 256))
            (if (assoc 6 js1) (assoc 6 js1) (cons 6 "BYLAYER"))
            '(100 . "AcDbPolyline")
            '(90 . 3)
            '(70 . 0)
            '(43 . 0.0)
            (cons 38 0.0)
            (cons 39 (getvar "THICKNESS"))
            (cons 10 (car l3))
            '(40 . 0.0)
            '(41 . 0.0)
            '(42 . 0.0)
            '(91 . 0)
            (cons 10 (cadr l3))
            '(40 . 0.0)
            '(41 . 0.0)
            '(42 . 0.0)
            '(91 . 0)
            (cons 10 (caddr l3))
            '(40 . 0.0)
            '(41 . 0.0)
            '(42 . 0.0)
            '(91 . 0)
            (cons 210 dxf_210)
    (T
      (princ "\nCan't fillet lines in differents planes!")
  (prin1)
Message 9 of 13
pendean
Community Legend
Community Legend
@CADaSchtroumpf The LISP only works on two lines, stops working on any PLINE it creates if the user needs more than two lines completed.
Message 10 of 13
Kent1Cooper
.... selecting lines fillet with zero radius and join them in one go so it turns into a Pline. ....
Won't something as simple as this do?
(defun C:FZJ ; = Fillet at Zero radius and Join
  (/ L1 L2)
  (setvar 'filletrad 0)
  (setq L1 (entsel "\nFirst Line/Arc to FZJ: "))
  (redraw (car L1) 3)
  (setq L2 (entsel "\nSecond Line/Arc to FZJ: "))
  (command "_.fillet" (cadr L1) (cadr L2))
  (initcommandversion)
  (command "_join" (car L1) (car L2) "")
  (prin1)
[Somehow, without the (initcommandversion), the JOIN command doesn't operate as expected from inside an AutoLisp (command) function.]
It works with Arcs as well as Lines [you never explicitly answered my question about whether you meant Line objects specifically, but I assume that], and with Polylines, too, though in that case you need to give it an extra Enter to finish selection in the JOIN command.
Kent Cooper, AIA
Message 11 of 13
pendean
Community Legend
Community Legend
The simplest old-school workflow is to convert the first picked line to a PLINE, then just FILLET away until you run out of lines to "join".
Message 12 of 13
Kent1Cooper
@pendean wrote:
.... convert the first picked line to a PLINE, then just FILLET away ....
An interesting thought.  If the OP would still want to use it on only two things:
  (/ L1)
  (setvar 'peditaccept 1)
  (command
    "_.pedit" (car L1) ""
  (prin1)
But it has drawbacks in relation to Arcs [which they may not care about].  You can't Fillet a Polyline and an Arc, or a Polyline arc segment and a Line, but you can two Polylines, whether line or arc segments.  So the above doesn't work if the second thing picked is an Arc, but it does if it's a Polyline arc.  And if the first thing picked is an Arc, it doesn't work if the second one is a Line, but it does if it it's a Polyline line.  It could overcome that with more code, by also converting the second thing to a Polyline before Filleting.
Kent Cooper, AIA
Message 13 of 13
Sea-Haven
This works with lines only adding arcs complicates things. In code below maybe can erase arc then ask for next segment. Need some true examples in a supplied dwg. It also relies on a bit of common sense when picking objects so fillet will work.
; simple fillet multi lines with radius zero
; By AlanH July 2024
(defun c:F0 ( / L1 pt typ ent)
(setq pt (cadr l1))
(setq typ (cdr (assoc 0 (entget (car l1)))))
(if (= typ "LWPOLYLINE")
  (princ)
  (command "pedit" (car l1) "")
(while (setq ent (entsel "\nPick next line - arc Enter to exit "))
(command "Fillet" pt (cadr ent))
(setq pt (cadr ent))
(princ)
(c:f0)
