Fill out polyline attribute based on block snapped to start and end point
cherrygate
cherrygate
Hi all,
I am struggling a bit with this one - I am trying to fill out object data table attributes of many polylines and lines based on the point it starts and ends at. The line it starts at is a block with an attribute + OD data (both have the data we need) - and the line ends at at similar block with an attribute + data table. The blocks should be exactly snapped to the start/end points.
I have attached an example DWG below - the "ID" from the "pole" block should go into the "start_spli" of the line, and the "addresslin" from the "house" block should go into the "end_splice" of the line.
I really appreciate any help with this, thank you!!
DWG: https://drive.google.com/file/d/1uYcjKZ-f-7IKqWCK_g7KzGEZu6kgIvrM/view?usp=sharing
Sea-Haven
I think I wrote this based on examples at Afralisp, should be a case of changing get to put.
; simple object data example
; By Alan H July 2019
(defun c:odtest ( / ent ty odname dia material)
(setq ent (car (entsel "\n Select Polyline (or press Enter to Exit): ")))
(setq ty (cdr (assoc 0 (entget ent))))
	(if (and (eq "LWPOLYLINE" ty)
	  (/= (setq odname (ade_odgettables ent)) nil)
	 (progn
           (setq dia (ade_odgetfield ent odname "Diameter" 0))
           (setq mat (ade_odgetfield ent odname "Material" 0))
           (alert (strcat "Material: " mat " \nDiameter " (rtos dia 2 2) (chr 34) " Main"))
(princ)
(c:odtest)
