fill on a title block (with attributes) with xls data
Good morning
I would need to find a way (and create a command!!) to "automatically" fill numerous title blocks (n°, name, date, title...made according to defined geometric grid, not a typical xls row-column grid) using the data present in an xls file. This xls file will have to remain linked to the drawings, should it be necessary to modify it.
1 xls file...many dwg files....many title blocks...
Best Regards
Luca, Rome - Italy
maratovich
It is possible to replace attributes, but not always, to understand you need a sample of your title block file.
You cannot bind xls to attributes.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Sea-Haven
Also need a sample xls.
VBA
....I've seen this process work perfectly!!!....with a binded xls
I will try to add some pictures...
cad
xls
