Fastest Way Through Every Line
rpajounia
Message 1 of 32
rpajounia
So i know people have the traveling sales man theory but that has to do with end points. My problem has to do with lines. I need a function that will tell me the fastest way through each line. i always start at ( 3048, 1828.8 ). I setup a drawing with an example output. My output is not the fastest or shortest distance traveled but that is what im trying to figure out
Start X3048.000000000000 Y1828.800000000000
Go To X4267.200000000002 Y1828.800000000000
Go To X6096.000000000001 Y1828.800000000001
Go To X6096.000000000001 Y2362.200000000001
Go To X5537.200000000002 Y2362.200000000001
Go To X4267.200000000002 Y2362.200000000000
Go To X4267.200000000000 Y3632.200000000002
Go To X5537.200000000002 Y3632.200000000002
Go To X5537.200000000002 Y3225.800000000003
Go To X5537.200000000002 Y2768.600000000001
Go To X5994.400000000003 Y2768.600000000001
Go To X6096.000000000003 Y2768.600000000001
Go To X5994.400000000003 Y3225.800000000003
Go To X5537.200000000000 Y3225.800000000003
Go To X4267.200000000002 Y3632.200000000002
Go To X4267.200000000000 Y3657.600000000001
Go To X3048.000000000000 Y3657.600000000001
Go To X3048.000000000000 Y1828.800000000000
Replies (31)
Message 21 of 32
daniel_cadext
As I mentioned above, IMHO, you should consider using a graph library.
Like network https://networkx.org/  , like in my python sample PyRxCmd_doit2
Even if you hack your way through it, the algorithms are fast.
It’s a cyclic graph, so I’d start with finding the longest cycle
simple_cycles
https://networkx.org/documentation/stable/reference/algorithms/generated/networkx.algorithms.cycles....
https://or.stackexchange.com/questions/9786/number-of-simple-cycles-on-the-graph
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 22 of 32
rpajounia
Unfortunately there is no penup situation. I think my best bet since my starting point is always the same is make a variation of all the possible routes it can take to visit all the lines and see which is the shortest route
Message 23 of 32
john.uhden
@rpajounia ,
That way, my friend, is a daunting task in itself, but probably the correct answer.
How about if you remove the governor from the machine to speed it up? 🤔
When I was a youngster a friend lent me his 3hp outboard to use on my 8' pram (dinghy).
I bent back the governor and got that little boat up on a plane (no, not an aircraft).
John F. Uhden
Message 24 of 32
Sea-Haven
Given no pen up maybe trace over with a new pline. Just try to minimize double runs. Use a bright color and say a width so obvious if a line is missed.
Message 25 of 32
john.uhden
@Sea-Haven ,
Yep, often times the eye is better than the app.
John F. Uhden
Message 26 of 32
rpajounia
i agree im currently looking into TSP and trying to see if there is a way to modify it to do plines instead of points and work with edges plus if its going from 1 point to another see if its a pline if its not a pline that has the same start/end points then use the shortest route function which i found a script for to get to that point but any help on this would be lovely
Message 27 of 32
john.uhden
@rpajounia ,
Okay, I give up.  What is TSP...
  • teaspoon?
  • Thrift Saving Plan?
  • Theatrical Stage Production?
  • Tongue Sensory Perception?
  • TriSodiumPhosphate?
  • Tremendously Sharp Pencil?
  • Torn Solar Plexus?
  • Tough Spouse Proclamation?
  • Tertiary Sewage Pretreatment?
  • Temporary Sanity Psychosis?
  • Terribly Stupid Pun?
WHAT?!
John F. Uhden
Message 28 of 32
daniel_cadext
https://en.wikipedia.org/wiki/Travelling_salesman_problem
Message 29 of 32
john.uhden
@daniel_cadext ,
I think that's like my ROUTE.lsp function I responded with some time ago, except as you pointed out, it doesn't allow you to visit any city (point) more than once.  In this case we may have to visit Peoria a few times just to get to Kalamazoo.
John F. Uhden
Message 30 of 32
daniel_cadext
this is networkx TSP solver applied.  toggling the cycle flag
import traceback
from pyrx_imp import Rx, Ge, Gi, Db, Ap, Ed
import networkx as nx
def PyRxCmd_doit():
    try:
        filter = [(Db.DxfCode.kDxfStart, "LWPOLYLINE")]
        ssres: tuple[Ed.PromptStatus, Ed.SelectionSet] = Ed.Editor.select(filter)
        if ssres[0] != Ed.PromptStatus.eOk:
            raise Exception("Oops {}: ".format(ssres[0]))
        G = nx.Graph()
        plines = [Db.Polyline(id) for id in ssres[1].objectIds()]
        for pline in plines:
            sp = pline.getStartPoint()
            ep = pline.getEndPoint()
            G.add_edge(sp,ep,weight=sp.distanceTo(ep))
        tsp = nx.approximation.traveling_salesman_problem
        tsppath = tsp(G, cycle=False)
        #Ed.Core.grDrawPoly3d(tsppath)
        db = Db.curDb()
        plPath = Db.Polyline(tsppath)
        plPath.setColorIndex(1)
        db.addToModelspace(plPath)
    except Exception as err:
        traceback.print_exception(err)
Message 31 of 32
rpajounia
so pretty much your almost there just missing 2 lines from the diagram. i think the main issue is were cycling through end points instead of plines. See if there is a way to set a unvisited factor
Message 32 of 32
daniel_cadext
Not using points, only edges. (G.add_edge(sp,ep,weight=sp.distanceTo(ep)))
I suppose it would be possible to create a map of the edges to find edges not traveled
I read the Depth First Search might be better suited.
https://networkx.org/documentation/stable/reference/algorithms/traversal.html#module-networkx.algori...
Got side tracked though
