Failed in creating the Geometry IntentUnspecified error (Exception from HRESULT: 0x800004005 (E_FAIL)
Message 1 of 1
I have a code that can "included" any 3D Sketch in my Drawing, and then generate dimension for all the lines on each view. So far, it works fine with the Inventor Professional 2018 version, but with Inventor 2018 (standard?) it keep giving out this error:
Failed in creating the Geometry IntentUnspecified error (Exception from HRESULT: 0x800004005 (E_FAIL))
Do anyone know what is going on with this?
Try
            Dim oAsmComp As AssemblyDocument
            oAsmComp = frontview.ReferencedDocumentDescriptor.ReferencedDocument
            Dim occ As ComponentOccurrence
            occ = oAsmComp.ComponentDefinition.Occurrences.Item(1)
            Dim part As PartDocument = Nothing
            part = occ.ReferencedDocumentDescriptor.ReferencedDocument
            Dim oProx As Sketch3DProxy = Nothing
            occ.CreateGeometryProxy(Sketch3D, oProx)
            Call frontview.SetIncludeStatus(oProx, True)
            For Each line As SketchLine3D In oProx.SketchLines3D
                Dim drawingCurves = frontview.DrawingCurves(line)
                Dim drawingCurveIntent = oSheet.CreateGeometryIntent(drawingCurves(1))
                Dim dimPoint = m_inventorApplication.TransientGeometry.CreatePoint2d(34, 22)
                Dim Gendim As LinearGeneralDimension
                Gendim = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(dimPoint, drawingCurveIntent)
                Gendim.CenterText()
                Dim oDimsToBeArranged As ObjectCollection
                oDimsToBeArranged = m_inventorApplication.TransientObjects.CreateObjectCollection
                oDimsToBeArranged.Add(Gendim)
                oSheet.DrawingDimensions.Arrange(oDimsToBeArranged)
                Gendim.Style.TextStyle.FontSize = 0.254
                Gendim.Style.LinearPrecision = LinearPrecisionEnum.kSixteenthsFractionalLinearPrecision
                Gendim.Style.LinearUnits = UnitsTypeEnum.kFootLengthUnits
                Gendim.Style.DisplayFormat = DisplayFormatEnum.kFractionalNotStackedFormat
            Next
        Catch ex As Exception
            MsgBox("Failed in creating the Geometry Intent" + ex.Message)
        End Try
Another question:
This code, every time it called out an dimension, it must put the point at (34,22) before arrange-ing it, is there a better way to do this?  Also, I tried to get the Gendim.Style formats outside of the For loop, but keep failing. Please help me! Thank you.
Replies (0)
