Extracting elements(information/coordinates) layer by layer
I am fairly new to AutoCad, so please excuse my little experience.
I have a map with different lines, circles etc. Elements which belong together are on the same layer. I am trying to find a way to extract all information (think the build in Dataextract function) [coordinates of beginning/end, length, radius etc] to a csv file or excel file, but layer by layer.
I tried different codes with the ssget function, but everything failed so far.
I am using AutoCAD 2016 with Express-Tools on Windows 10.
Any help is appreciated.
Johanna
john.uhden
I guess I would start by using tblnext to iterate through all the layers and do an ssget on each layer name.
For example:
(setq rewind 1)
(while (setq layer (tblnext "layer" rewind))
  (setq rewind nil
           layer (cdr (assoc 2 layer))
  (or
    (setq ss (ssget "X" (list (cons 8 layer))))
    (setq ss (ssadd))
  (setq i (sslength ss))
  (while (> i 0)
    (setq e (ssname ss (setq i (1- i)))
             ent (entget e) ;; entity data
             obj (vlax-ename->vla-object e) ;; to get vla-object data
    (extract e) ;; extract function not provided; that's up to you
    ;; or (extract obj) ;; that's up to you too.
John F. Uhden
Thank you. It worked like a charm.
