Extracting Coordinates from a polyline
Bin2009
Bin2009
I am trying to get a lisp extract the X and Y coordinates of series points on a polyline
First situation is the points divide polyline with  equal interval (for example 1 meter).
without lisp, I can do is use measure command, put points along polyline every 1 meter, then use dataextraction to get all points coordinates.
Second situation, the points have equal increasing on x. For example, increase 1 meter each time, I need find y value at the point x =  1, 2, 3,.... until end.
without lips, I can do is drawing array of lines with interval 1 meter, then trim them by the polyline, use dataextaction to get all lines end point y value.
I hope can have some lisps to solve my two problems and speed up my work, highly appreciate if anyone can help!
Bin
kajanthangavel
Try this.
for your first requirement
It working Like this
(defun c:brk (/ *error* k_len kchain file ov dis cEnt pt)
  (vl-load-com)
	(defun *error* (msg)
		(close file)
		(command "_.UNDO" "_B")
		(mapcar 'setvar svnames svvals)
		(if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
		(princ (strcat "\n<< Error: " msg " >>")))
		(princ)
	(command "_.UNDO" "_M")
	(vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
	(setq svnames '(osmode cmdecho blipmode plinewid))
	(setq svvals (mapcar 'getvar svnames))
	(setq kchain 1)
	(setq file (open (strcat (getvar 'dwgprefix) "coordnate.csv") "w"))
	(mapcar 'setvar svnames '(0 0 0 0))
	(write-line (strcat "Number" "," "X-Coor" "," "Y-Coor" "," "X-Coor") file)
	(or (= (type k_len) 'REAL)(setq k_len 1.0))
	(not (initget 6))
		(if (setq dis (getdist (strcat "\nLength of stripe <" (rtos k_len (getvar "lunits") 2) ">: ")))
			(setq k_len dis)
			(setq dis k_len)
	(while (and (setq cEnt (car (entsel "\nSelect Polyline: ")))
				(vl-position (cdadr (entget cEnt)) '("LINE" "LWPOLYLINE" "POLYLINE" "ARC" "SPLINE")))
		(while (and (setq pt (vlax-curve-getPointatDist cEnt dis))
					(>= (distance pt (vlax-curve-getEndPoint cEnt)) dis))
		(command "_.break" (list cEnt pt) "_F" pt pt)
			(princ (strcat "
"(rtos kchain 2 0) "," (rtos (car pt) 2 3) "," (rtos (cadr pt) 2 3) "," (rtos (caddr pt) 2 3)))
			(progn
				(write-line (strcat (rtos kchain 2 0) "," (rtos (car pt) 2 3) "," (rtos (cadr pt) 2 3) "," (rtos (caddr pt) 2 3)) file)
				(setq kchain (+ kchain 1))
		(setq cEnt (entlast))
	(close file)
	(vla-endundomark doc)
(princ)
I am not Lisp Expert
kajanthangavel
This it your 2nd requirement
This is working like thisThis is working like this
This is working sample
Try this code
(defun C:xcoor (/ *error* doc svnames svvals ss n plobj LL xl xlobj intc file kchain k_len dis)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
	(close file)
    (princ)
(setq file (open (strcat (getvar 'dwgprefix) "X_level_corrdinate.csv") "w"))
(write-line (strcat "Number" "," "X-Coor" "," "Y-Coor") file)
(setq kchain 1)
	(not (initget 6))
		(if (setq dis (getdist (strcat "\nX axsi Length <" (rtos k_len (getvar "lunits") 1) ">: ")))
			(setq k_len dis)
			(setq dis k_len)
(prompt "\nSelect Polyline(s),")
  (if (setq ss (ssget '((0 . "*POLYLINE"))))
    (progn
      (repeat	(setq n (sslength ss))
				(setq plobj (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
				(vla-getboundingbox plobj 'minpt 'maxpt)
				(setq LL (vlax-safearray->list minpt))
				(command "_.xline" "_ver" LL "")
				(setq xl (entlast) xlobj (vlax-ename->vla-object xl))
				(repeat (1+ (fix (/ (- (car (vlax-safearray->list maxpt)) (car LL)) dis)))
					(setq intc (vlax-invoke plobj 'IntersectWith xlobj acExtendNone))
					(princ (strcat "
					" (rtos kchain 2 0) " " (rtos (car intc) 2 3) " " (rtos (cadr intc) 2 3)))
					(write-line (strcat (rtos kchain 2 0) "," (rtos (car intc) 2 3) "," (rtos (cadr intc) 2 3)) file)
					(command "_.move" xl "" (list dis 0) "")
				(entdel xl)
    (prompt "\nNo Polyline(s) selected.")
(close file)
(princ)
I am not lisp expert
I hope this is help you.
Bin2009
Hello kajanthangavel,
Thank very much for your lisp, I think you helped me before.
I tried this lisp, it works great when the polyline made from lines, but if the polyline contain curves, it looks can't go through, could you please help, I attach one polyline I need work with.
Thanks so much!
Bin
Bin2009
Thank very much for your lisp,  it works great!
Bin
kajanthangavel
Hi
Its work for me
See that, working sample.
Try with this lisp.
(If  (not work)
      (post your AutoCAD Version)
      (Enjoy)
"Sorry for late reply, Because I went vacation."
