Extracting Attribute Value from Title Block
I'm trying to edit a lisp file and not having much luck.
I need to extract an attribute value from a block and recall it later in the lisp.
The block is called DAA-Title-Rev, the attibute tag is called REV and the value should be called lat_rev.
I'd be reallygrateful if someone could point me in the right direction with this.
May thanks in advance.
rkmcswain
Pointing away....
;;Use the MeGetAtts function found at: ;;http://www.menziengineering.ch/Downloads/Download.htm#2
;;Start with this to get "obj"
(setq sel (entsel))
(setq ent (car sel))
(setq obj (vlax-ename->vla-object ent))
(MeGetAtts obj)
R.K. McSwain     | CADpanacea | on twitter
Thanks for the reply. I've looked at the link but sorry I don't understand.
Could you possibly elaborate a bit please?
rkmcswain
Please elaborate for us.
Are you trying to "edit a lisp file" as your original post says, or are you looking for someone to write you some code for a specific task? If the former, then post the code you have so far please.
The code I posted is very simple autolisp and if that doesn't make sense, we need to know in order to better help you.
ahmed.abdelmotey
can you explain more what you need?
Ahmed Abd-Elmotey
Landscape Architect & beginner lisp programmer
