Extract Block Geometery & Attribute
Jonathan3891
Advisor Advisor
Message 1 of 15
Jonathan3891
I thought I had this working until I realized that a data extraction template is tied to a single drawing. Data extraction gives me exactly what I want but I want to automate this completely without any interaction from the user.
I want to be able to extract pile data (a block) to a csv file containing:
Position X
Position Y
Position Z
Dynamic Block Information
Attribute
Is what I'm asking possible without using Data Extraction?
I found one on the forums but it wouldn't do anything https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/data-extraction-amp-attributes-on-dy...
Jonathan Norton
Blog | Linkedin
Accepted solutions (4)
Replies (14)
Message 2 of 15
dlanorh
Position X
Position Y
Position Z
Attribute
The lisp in the marked solution of the indicated thread (DBtxt.LSP) has hard wired block names and attribute tag names. These are at the top of the lisp file.
	(setq data   nil
	      bnames "SAMPLEB,SAMPLEC,`*U*"
	      Tags '("TAG1" "TAG2")
	      ss     (ssget "_X"
			    (list '(0 . "INSERT") '(66 . 1) (cons 2 bnames))
Open the file in a text editor and change the items marked in red above to reflect your block name and tag name. Save the file to a slightly different name,  then try loading and running the altered lisp.
I am not one of the robots you're looking for
Message 3 of 15
Jonathan3891
I've changed the block and tag names in that lisp. I just couldn't get it to do anything.
Jonathan Norton
Blog | Linkedin
Message 4 of 15
dlanorh
Your block doesn't have a visibility state and thus failed one of the and conditions.
I have modified the lisp (attached) and it should now work with your block, but it won't display the stretch distance.
It must be run on a drawing that has been saved at least once, and will write a text file (csv format) containing the attribute value followed by the x,y and z coords.
Message 5 of 15
dlanorh
I realise that this is not in the format you require, but it is to show that data extraction is possible without using autocad's data extraction tool and a template.
If you rename the *.txt file to *.csv it should load into excel.
Message 6 of 15
dlanorh
Try the attached. This collects all the information and sorts by pile number (assuming it is only numeric) and writes the csv to the same directory as the drawing (alterable by changing the path or prompting for a path)
Message 7 of 15
Jonathan3891
Thank you for your help.
How do I change the units from inches to feet?
Jonathan Norton
Blog | Linkedin
Message 8 of 15
dlanorh
If you are refering to the "pile length" dynamic property
change the red item below
(write-line (strcat (rtos (car i_pt) 2 3) "," (rtos (cadr i_pt) 2 3) "," (rtos (caddr i_pt) 2 3) "," (rtos p_len 2 3) "," val) fp)
to
(write-line (strcat (rtos (car i_pt) 2 3) "," (rtos (cadr i_pt) 2 3) "," (rtos (caddr i_pt) 2 3) "," (rtos (\  p_len 12) 2 3) "," val) fp)
This will preserve the drawing units but display the output in the csv file in decimal feet.
Message 9 of 15
Jonathan3891
Thank you @dlanorh for all your help.
Can I make one more request?
How do I change the information and order to the following:
Pile No, Northing, Easting, Insert Elevation, Pile Length
Jonathan Norton
Blog | Linkedin
Message 10 of 15
Jonathan3891
Scratch that. I got all that figured out.
I do need to control the location of the csv file though. Is that something that can be done easily?
Jonathan Norton
Blog | Linkedin
Message 11 of 15
dlanorh
Is the csv file location something that can be hard coded or is it something that will vary? Both are relatively easy
Message 12 of 15
Jonathan3891
It will be hard coded.
Jonathan Norton
Blog | Linkedin
Message 13 of 15
dlanorh
Find this line in the setq at the top of the lisp :
path (getvar 'dwgprefix)
Change it to
path "(Drive) :/(Path to Save Location)" ; use "/" as the directory divider i.e. "C:/Users/....../"
Hopefully that should work.
Message 14 of 15
Jonathan3891
Thank you again @dlanorh !
Would it be easy to have it check if in model space and if the block exist with an alert? And an alert to upon completions?
I've tried but haven't gotten it to work.
((alert "Command unavailable in Modelspace"))
((alert "Pile_Block not found!"))
((alert "Pile data exported sucessfuly"))
Jonathan Norton
Blog | Linkedin
Message 15 of 15
dlanorh
I have attached an updated lisp that will need editing.
The lisp can run from modelspace or paperspace, so there is no need to check. I have included them but commented out so you can see how i have structured them within the cond statement.
Below is the top of the attached lisp.
I have included a local error function (just in case). The main purpose of this is to close the open file if an error should occur whilst it is open. This error routine replaces AutoCAD's error routine only for the duration of the lisp.
The red items are the needed parts for the model/paper space checks. The sections in the "cond" statement have been commented out. If you want to remove them, only remove items coloured red.
The orange item is a check to ensure the drawing has been saved. This is to avoid a disconnected drawing csv file pairing. The program will still work if the line is removed.
The indigo line is the check for the block.
Please note that the path variable will need setting to the path where you require the csv file to be saved.
(defun c:EPD ( / *error* c_doc b_nme tag ss path f_name fp val i_pt p_len b_lst)
  (defun *error* ( msg )
    (if fp (close fp))
    (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nOops an Error : " msg " occurred.")))
    (princ)
  );end_*error*_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_spc (vla-get-activespace c_doc);Remove this line if you don't want a model/paper space check
        b_nme "PILE_BLOCK"
  );end_setq
  (cond ;( (= acpaperspace c_spc) (alert "Command Unavailable in Paperspace"))
        ;( (= acmodelspace c_spc) (alert "Command Unavailable in Modelspace"))
        ( (= (getvar 'dwgtitled) 0) (alert "Drawing not Saved"))
        ( (not (tblobjname "block" b_nme)) (alert (strcat "Block " b_nme " NOT available in drawing")))
        ( (and  (setq b_lst nil
                      path (getvar 'dwgprefix);CHANGE THIS TO YOUR REQUIRED PATH TO CSV FILE!!!
