Extract Block Attributes into Premade Excel Sheet
My goal is to extract my block attributes straight into a premade excel file to format a Bill of Materials. After doing some digging through the forums, I found out that this is impossible to extract data into an existing table. Is this true?
If so, now my approach is to make a new excel file using the Data Extraction command, followed by copy and pasting it into the preexisting BOM file. In order to do so, I would need to change the format of the data extraction standard table to accommodate the format from my BOM excel sheet. I added in an excel sheet screenshot to clarify on the format below. To elaborate, if multiple Tag#’s fall under the same Tag Prefix AND Item# then it would automatically combine the rows together. Thus I would need a single header for multiple columns of data.
Furthermore, as this would be a bill of materials, it would cover more than one drawing. Would it be possible to take a sheet set to complete this process or some other grouping method instead of individually going through every drawing?
