Hi, I'm pretty new to AutoCAD, and I was wondering if anyone knows how to use the Expression option for Scale when using the SWEEP command. I'm not sure if it uses LISP expressions or mathematic expressions like cos(x).
I've already tried basic arithmetic like (+ 5 2) and obviously got a scale factor of 7. I'm wondering if there is a way to get a modulating scale for one sweep, such as the scale factor starting off as 1, then going to 2, 4, .5, and so on. Almost as if it were following the graph of an equation. What I have in mind if something like the structure of this vase:
And yes, I realize this can be creating by lofting several profiles. I'm just wondering if it can also be made by sweeping, or if the Expression option for scaling a sweep has some different use.
I hope I communicated everything correctly, and I will greatly appreciate any help you guys have! Thanks!
