exporting the coordinates of the autocad parcel to autocad excel
mirqalib.m
Message 1 of 31
mirqalib.m
Hello. I drew the parcel in Autocad and copy the coordinates in the list command, for example
at point X=670828.0000 Y=4433484.0000 Z= 0.0000
at point X=670915.0000 Y=4433441.0000 Z= 0.0000
at point X=670879.0000 Y=4433356.0000 Z= 0.0000
With the help of a macro in excel, I get the coordinates, point numbers and intermediate distances in the excel file. Then I add my header to this excel and paste it in autocada (next to my parcel).
Is there a lisp that I can do this action in autocad excel without the help of excel and macro. Thank you in advance.
Replies (30)
Message 21 of 31
komondormrex
sure, check update.
Message 22 of 31
mirqalib.m
You're great. Thank you.
Message 23 of 31
komondormrex
you are welcome)
Message 24 of 31
mirqalib.m
it gives this error on my home computer. is it possible to fix it?
Message 25 of 31
komondormrex
try to add (vl-load-com) at the very beginning of the code and reload lisp. has to help.
Message 26 of 31
mirqalib.m
I'm having trouble rounding the dimensions. Autocad writes wrong on the table.
Message 27 of 31
komondormrex
check update in 13.
Message 28 of 31
komondormrex
fyi, distance between vertex 1 and vertex 2 is 95.94999999977408, which rtos-ed with (rtos 95.94999999977408 2 1) to "95.9", so there is no autocad mistake in that. other two were mine.
if you do not supposed to copy/paste cells' values there might be implemented internal formatting for cells' content.
Message 29 of 31
mirqalib.m
number of points 1-13. but it gives 1-17 on the table. It divides the distances
Message 30 of 31
komondormrex
very strange. can't simulate this error. i ran it 10 times on your dwg and every time got 13.
Message 31 of 31
mirqalib.m
It may occur when the distances are long and the dots are large. The second time I run lisp, it gives correct results. interesting
