I hope it helps.
Let us know if it worked.
Best Regards, Luís Augusto
(defun C:TEST ()
;; Write CSV - Lee Mac
;; Writes a matrix list of cell values to a CSV file.
;; lst - [lst] list of lists, sublist is row of cell values
;; csv - [str] filename of CSV file to write
;; Returns T if successful, else nil
(defun LM:writecsv (lst csv / des sep)
(if (setq des (open csv "w"))
(progn
(setq sep
(cond ((vl-registry-read
"HKEY_CURRENT_USER\\Control Panel\\International"
"sList"
(foreach row lst (write-line (LM:lst->csv row sep) des))
(close des)
t
;; List -> CSV - Lee Mac
;; Concatenates a row of cell values to be written to a CSV file.
;; lst - [lst] list containing row of CSV cell values
;; sep - [str] CSV separator token
(defun LM:lst->csv (lst sep)
(if (cdr lst)
(strcat (LM:csv-addquotes (car lst) sep)
sep
(LM:lst->csv (cdr lst) sep)
(defun LM:csv-addquotes (str sep / pos)
(cond
((wcmatch str (strcat "*[`" sep "\"]*"))
(setq pos 0)
(while (setq pos (vl-string-position 34 str pos))
(setq str (vl-string-subst "\"\"" "\"" str pos)
pos (+ pos 2)
(strcat "\"" str "\"")
(str)
;; Insert Nth - Lee Mac
;; Inserts an item at the nth position in a list.
;; x - [any] Item to be inserted
;; n - [int] Zero-based index at which to insert item
;; l - [lst] List in which item is to be inserted
(defun LM:insertnth (x n l)
(cond
((null l) nil)
((< 0 n) (cons (car l) (LM:insertnth x (1- n) (cdr l))))
((cons x l))
(defun openfile (file / sh)
(setq sh (vla-getinterfaceobject
(vlax-get-acad-object)
"Shell.Application"
(vlax-invoke-method sh 'open (findfile file))
(vlax-release-object sh)
(defun GetCurveLength (ent /)
(setq ent (vlax-ename->vla-object ent))
(vlax-curve-getDistAtParam
ent
(vlax-curve-getEndParam ent)
(setq lineList '(
"FENCELINE1"
"FENCELINE2"
"GAS_LINE"
"HOT_WATER_SUPPLY"
(setq lineList
(mapcar
'(lambda (lineStyle)
(if (setq
ss (ssget "_X"
(list '(0 . "*LINE") (cons 6 lineStyle))
(progn
(setq index 0
totalObj 0
(repeat (sslength ss)
(setq totalObj
(+ totalObj (GetCurveLength (ssname ss index)))
(setq index (1+ index))
(list lineStyle (rtos totalObj 2))
lineList
(setq lineList (LM:insertnth
(list "Line List" "------------------")
0
lineList
(setq bom lineList)
(setq blockList '(
"oooo"
"bbbb"
(setq blockList
(mapcar
'(lambda (blkName)
(if (setq
ss (ssget "_X"
(list '(0 . "INSERT") (cons 2 blkName))
(progn
(setq index 0
totalObj (sslength ss)
(list blkName (rtos totalObj 2))
blockList
(setq blockList (LM:insertnth
(list "Block List" "------------------")
0
blockList
(setq bom (append bom blockList))
(setq hatchColorList
30
152
(mapcar
'(lambda (color)
(if (setq
ss (ssget "_X"
(list '(0 . "HATCH") (cons 62 color))
(progn
(setq index 0
totalObj 0
(cdr (assoc -1 (entget (ssname ss index))))
(setq totalObj
(+ totalObj (vla-get-area ent))
(list (strcat "HatchColor_" (rtos color 2 00))
(strcat
"Area = "
(if (or (= (getvar "lunits") 3)
(= (getvar "lunits") 4)
(strcat
(rtos totalObj 2)
" sq. in. ("
(rtos (/ totalObj 144) 2)
" sq. ft.)"
(rtos totalObj)
hatchColorList
(LM:insertnth
(list "Hatch List" "------------------")
0
hatchColorList
(setq bom (append bom hatchColorList))
(LM:writecsv bom (strcat (getvar 'DWGPREFIX) "BOM.csv"))
(openfile (strcat (getvar 'DWGPREFIX) "BOM.csv"))
(vl-load-com) (princ "TEST")
