Export Specific attribute named block X, Y coordinates to Excel
Yamishon_Noah
Message 1 of 12
Yamishon_Noah
Hi experts,
I have many blocks but its attribute  Tag is "TYPE" same for all blocks.
So, I want to extract only these block attributed Tag "TYPE" X & Y coordinates to Excel.
Sample drawing is attached.
Appreciate your helps
Yamishon Noah
Replies (11)
Message 2 of 12
pbejse
@Yamishon_Noah wrote:
Hi experts,
With Data Extraction you can this result...
It is not the attribute definitions coordinates but the blocks' insertion point
Is that what you're after? or something else?
Message 3 of 12
pbejse
(defun c:demo ( / LM:open ss i vl_e ins_point valid_tag All_data filetowrite)
;; pBe May 2018
;; Open  -  Lee Mac
;; A wrapper for the 'Open' method of the Shell Object
;; target - [int/str] File, folder or ShellSpecialFolderConstants enum
(defun LM:open ( target / rtn shl )
    (if (and (or (= 'int (type target)) (setq target (findfile target)))
             (setq shl (vla-getinterfaceobject (vlax-get-acad-object) "shell.application"))
        (progn
            (setq rtn (vl-catch-all-apply 'vlax-invoke (list shl 'open target)))
            (vlax-release-object shl)
            (if (vl-catch-all-error-p rtn)
                (prompt (vl-catch-all-error-message rtn))
                t
    (and
    	(setq ss (ssget "_X" '((0 . "INSERT")(66 . 1)(410 . "Model"))))
    	(setq csvfile (getfiled "Enter CSV file name" (getvar 'dwgprefix) "csv" 1))
	(repeat (setq i (sslength ss))
		(setq vl_e (vlax-ename->vla-object (ssname ss (Setq i (1- i)))))
		(setq ins_point (vlax-get vl_e 'Insertionpoint))
		(if (setq valid_tag
			   (Cdr (assoc "TYPE"
			       (mapcar '(lambda	(at)
					  (list (vla-get-tagstring at) (vla-get-textstring at))
				       (vlax-invoke vl_e 'GetAttributes)
			  (setq All_data (cons (list (vla-get-EffectiveName vl_e)
						     (strcat (Car valid_tag) ","
							     (rtos (car ins_point) 2) ","
							     (rtos (cadr ins_point) 2)
						     ) All_data))
	All_data
	(setq filetowrite (open csvfile "w"))
        (foreach itm (vl-sort All_data '(lambda (a b)(< (Car a)(car b))))
	    	(write-line (strcat (Car itm) "," (Cadr itm)) filetowrite))
	(not (close filetowrite))
	(LM:OPEN csvfile)
  (princ)
Message 4 of 12
Yamishon_Noah
Hello pBe,
Appreciate your reply and thanks a lot.
I don’t want to use Data extraction method.
Let me check your Lisp (posted) and will let you know.
Thanks again. 🙂
Message 5 of 12
Yamishon_Noah
Hi pBe,
your code works perfect.. awesome..
is it possible to save file as  "file_name".xlsx instead of user to enter name & CSV file.
Thanks a lot
Message 6 of 12
pbejse
well...
(defun c:demo ( /  ss i vl_e ins_point valid_tag All_data filetowrite xlCells Excel_exist col row)
;; pBe May 2018
  (if
    	(and
	  (setq All_data nil
				(if (setq valid_tag
					   (Cdr (assoc "TYPE"
								     (Car valid_tag) (rtos (car ins_point) 2) (rtos (cadr ins_point) 2)
								     All_data))
	  		All_data
	(cond
	  	(	(null All_data)		)
		(	(setq Excel_exist (vlax-get-or-create-object "Excel.Application"))
		 	(setq col 1 row 1)
		 	(setq  xlCells  (vlax-get-property
                                     (vlax-get-property
                                       (vlax-get-property
                                         (vlax-invoke-method
                                           (vlax-get-property Excel_exist "Workbooks")
                                             "Add"
                                         "Sheets"
                                       "Item" 1
                                     "Cells"
			((lambda (n)
				(foreach val '("Block Name" "Value" "X" "Y" )
				  (vlax-put-property xlCells 'Item row (setq n (1+ n)) val)
				  0
		 	(vlax-put-property xlCells 'ColumnWidth 15.00)
			  (setq row (1+ row))
			  	((lambda (n)
					(foreach val itm
					  0
		 	(vla-put-visible Excel_exist :vlax-true)
			(mapcar (function (lambda (obj)
					(and obj (eq 'VLA-OBJECT (type obj)) (not (vlax-object-released-p obj))
					      (not
					          (vl-catch-all-apply
					            (function vlax-release-object) (list obj)
			(list Excel_exist xlCells))
		 	(setq Excel_exist nil
			      xlCells nil)
		(	(setq csvfile (getfiled "Enter CSV file name"
				(strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)))   "CSV" 1))
			(close filetowrite)
		 	(startapp "notepad")
  (princ)
You'll be able to save the excel file to whatever name and location after the program ends.
HTH
Message 7 of 12
Yamishon_Noah
Hi HTH,
Thanks very much for your support on this, really appreciate it.
After command execution it opened excel (*.xlsx), where as i want to save as "Exported" name and same path of cad drawing kept and after msg box "exported"
Is it possible to update the code please?
YN
Message 8 of 12
Yamishon_Noah
Hi pBe,
Is it possible to do this step for multiple drawings at a time?
ex: I have 25 drawings in one folder
when I execute command it will ask to select folder and then export block coordinates as *.csv to the same folder (file name same as cad dwg).
I really appreciate your help on this.
thanks
Message 9 of 12
Yamishon_Noah
Any experts can help on this please?...
Message 10 of 12
I added one more tag in the attribute block.
I want to export all of tags and the contents
plz modify the codes once more. Thank you very much.
Message 11 of 12
Sea-Haven
I am sure if a donation is made the please change will occur faster.
There should be a answer block to excel lisp did you google ? Lots of youtube etc.
Message 12 of 12
pbejse
Are you Yamishon_Noah?  The way you ask for modification is as if you are the original poster.
