Export polyline data
subasio21
Message 1 of 9
subasio21
Hi, everyone!
I am searching for a lisp that can find all closed polylines in a drawing and export to excel their following information:
area, layer ,thickness , color, x-cordinate of area , y-cordinate of area , z-cordinate of area
ı added a sample dwg
if anyone can help me I would be gratfull
Replies (8)
Message 2 of 9
ВeekeeCZ
post a csv file with an example of 1 exported polyline to take a look at its structure.
Message 3 of 9
Kent1Cooper
And please define what you would mean by the X, Y and Z coordinates of an area.  Those of its centroid?  Of the middle of its bounding box?  For one with non-zero thickness, if you want the centroid, do you want the centroid of its drawing plane, or halfway up its thickness, or the top of its thickness?  Etc., etc.
Kent Cooper, AIA
Message 4 of 9
Sea-Haven
Is the area the face area baselength*thickness ? Add end areas ?
Message 5 of 9
subasio21
hi
sorry but ı dont know how to export polyline to csv
Message 6 of 9
subasio21
Hi
yes they are the center of its area , to calculate the weight center of all , I want the centroid of its  halfway up its thickness,
Message 7 of 9
subasio21
hi
only face plane  area
thanks all
Message 8 of 9
ronjonp
Here's a quickie;
(defun c:foo (/ _f _c c f fn o s x)
  ;; RJP » 2021-04-01
  (defun _f (s)
    (strcat (cond ((= 'real (type s)) (vl-string-right-trim "0" (rtos s 2 15)))
		  ((= 'int (type s)) (itoa s))
		  ((vl-princ-to-string s))
  (defun _c (o / a b)
    (if	o
      (progn (vla-getboundingbox o 'a 'b)
	     (mapcar 'set '(a b) (mapcar 'vlax-safearray->list (list a b)))
	     (mapcar '/ (mapcar '+ a b) '(2 2 2))
  (cond	((and (setq s (ssget '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1))))
	      (setq f (open (setq fn (strcat (getvar 'dwgprefix) "Results.csv")) "w"))
	 (write-line "AREA,LAYER,THICKNESS,COLOR,X,Y,Z" f)
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq c (_c (setq o (vlax-ename->vla-object e))))
	   (write-line
	     (apply 'strcat
		    (append (mapcar '(lambda (x) (_f (vlax-get o x))) '(area layer thickness color))
			    (mapcar '_f c)
	     f
	 (close f)
	 (alert fn)
  (princ)
Message 9 of 9
subasio21
thanks a lots
that's great !
